주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot A480 LCD Screen Replacement
필요한 것
  1. Canon PowerShot A480 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3개 중 1개 Canon PowerShot A480 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3개 중 2개 Canon PowerShot A480 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3개 중 3개
    • First, we will start by removing all of the black 5mm screws on the exterior.
    • Flip the camera upside down revealing two black screws on either side of the tripod mount.
    • Turn to the side of the camera closest to the lens to unscrew the third and final black screw.
    댓글 쓰기
  2. Canon PowerShot A480 LCD Screen Replacement: 2 단계, 이미지 3개 중 1개 Canon PowerShot A480 LCD Screen Replacement: 2 단계, 이미지 3개 중 2개 Canon PowerShot A480 LCD Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Open the rubber panel on the side of the camera to reveal the last two 5mm exterior screws which are silver.
    • Once you have removed the last of the screws, use an iFixit opening tool to separate the two halves of the camera.
    • Take a half of the camera in each hand and gently pry them apart, pulling up on the side across from where the buttons are located.
    댓글 쓰기
  3. Canon PowerShot A480 LCD Screen Replacement: 3 단계, 이미지 3개 중 1개 Canon PowerShot A480 LCD Screen Replacement: 3 단계, 이미지 3개 중 2개 Canon PowerShot A480 LCD Screen Replacement: 3 단계, 이미지 3개 중 3개
    • With the screen now exposed, you must unscrew the three silver 2mm screws attaching it to the body of the camera.
    • Use the iFixit opening tool to lift the screen away from the body so that the only thing connecting it to the rest of the camera is the thin, orange wire cable.
    • Using your pointer finger and thumb, firmly grasp the cable and pull it straight away from the camera to disconnect it.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order using your new LCD display.
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ian Nzabanita
회원 가입일: 05/06/19
193 평판
안내서 1개를 작성함
UW Tacoma, Team S1-G5, Cardinal Spring 2019 UW Tacoma, Team S1-G5, Cardinal Spring 2019 회원
UWT-CARDINAL-S19S1G5
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 56
전체 시간: 1,851
