주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot A540 Clock Battery Replacement
필요한 것
  1. Canon PowerShot A540 Clock Battery Replacement, Clock Battery: 1 단계, 이미지 1개 중 1개
    • Turn the camera upside down.
    • Press the tab to release the battery cover.
    댓글 쓰기
  2. Canon PowerShot A540 Clock Battery Replacement: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the internal Battery from the slot right above where the AA batteries fit.
    • This can be done with your fingers (as pictured) or with tweezers.
    댓글 쓰기
  3. Canon PowerShot A540 Clock Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Replace the internal battery.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Cooper Hale
회원 가입일: 03/22/15
598 평판
안내서 3개를 작성함
Baylor, Team 7-12, Williams Spring 2015 Baylor, Team 7-12, Williams Spring 2015 회원
BU-WILLIAMS-S15S7G12
3 회원들
안내서 20개를 작성함
6가이드 댓글
Very useful information, thank you.
Bob C - 답글 공유
Also, nice fingernails!
Charlie Shaw - 답글 공유
I am a retired professional phographer with 60 years of experience and own several cameras including FX. Yet I didn’t remember how to change the clock battery on this little gem which I occasionally still use. Thanks for the refresher!
MASSEY JONES - 답글 공유
There is nothing in the manual concerning this battery. When I was told it needed replacement I was lucky to find this clear explanation to do it. It was a CR1220 battery. Thank you, Cooper Hale.
Thomas Combs - 답글 공유
Hello! I did this but my camera keeps saying that the battery is empty. Anyone know what else I can try? Or is my camera just broken?
Sanne x - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 36
지난 7일: 62
지난 30일: 179
전체 시간: 12,631
