주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot A540 Function Key Motherboard Replacement
필요한 것
    1. Canon PowerShot A540 Function Key Motherboard Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Canon PowerShot A540 Function Key Motherboard Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
      • Turn off the camera.
      • Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
      댓글 쓰기
    2. Canon PowerShot A540 Function Key Motherboard Replacement: 2 단계, 이미지 1개 중 1개
      • Turn the camera upside down to view the "Card/Batt. Open" Cover.
      • Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
      댓글 쓰기
    3. Canon PowerShot A540 Function Key Motherboard Replacement: 3 단계, 이미지 1개 중 1개
      • Open "Card/Batt. Open" Cover.
      • Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
      댓글 쓰기
    4. Canon PowerShot A540 Function Key Motherboard Replacement: 4 단계, 이미지 1개 중 1개
      • Turn the camera to the right side of the LCD screen.
      • Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
      댓글 쓰기
    5. Canon PowerShot A540 Function Key Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Canon PowerShot A540 Function Key Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Canon PowerShot A540 Function Key Motherboard Replacement: 5 단계, 이미지 3개 중 3개
      • Gently remove the back cover.
      • Start at the bottom at the corner of the "Card/Batt. Open" Cover.
      • Then move onto the other edges and the top.
      • It may be tight at the top!
      댓글 쓰기
    1. Canon PowerShot A540 Function Key Motherboard Replacement, Function Key Motherboard: 6 단계, 이미지 2개 중 1개 Canon PowerShot A540 Function Key Motherboard Replacement, Function Key Motherboard: 6 단계, 이미지 2개 중 2개
      • Turn the camera to view the back.
      • Remove the one (1) 3.0 mm screw on the top right corner of the screen.
      • There is a small metal bar that rests on this frame. Keep it with the screws that have been removed from the camera.
      댓글 쓰기
    2. Canon PowerShot A540 Function Key Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Canon PowerShot A540 Function Key Motherboard Replacement: 7 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Lift the LCD Screen off of the back to view the attached ribbon cables.
      • Use tweezers to flip the black bar up.
      댓글 쓰기
    3. Canon PowerShot A540 Function Key Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Canon PowerShot A540 Function Key Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Canon PowerShot A540 Function Key Motherboard Replacement: 8 단계, 이미지 3개 중 3개
      • Gently pull the big ribbon out.
      • Gently pull the small ribbon out.
      • The small ribbon does not have a bar like the big ribbon.
      댓글 쓰기
    4. Canon PowerShot A540 Function Key Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Canon PowerShot A540 Function Key Motherboard Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the two (2) 3.0 mm screws with the Phillips head #000 screwdriver.
      댓글 쓰기
    5. Canon PowerShot A540 Function Key Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Canon PowerShot A540 Function Key Motherboard Replacement: 10 단계, 이미지 2개 중 2개
      • Remove the orange ribbon from the clamp by using a Spudger to push the bar up.
      댓글 쓰기
    6. Canon PowerShot A540 Function Key Motherboard Replacement: 11 단계, 이미지 1개 중 1개
      • Remove the Function Key Motherboard and replace.
      • There is another metal bar that comes off of the SD Card reader when screws are removed.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Cooper Hale
회원 가입일: 03/22/15
598 평판
안내서 3개를 작성함
Baylor, Team 7-12, Williams Spring 2015 Baylor, Team 7-12, Williams Spring 2015 회원
BU-WILLIAMS-S15S7G12
3 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 36
전체 시간: 1,272
