주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot A550 LCD Screen Replacement
필요한 것
    1. Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: 1 단계, 이미지 3개 중 1개 Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: 1 단계, 이미지 3개 중 2개 Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: 1 단계, 이미지 3개 중 3개
      • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
      • There are 2 screws on the left side (when looking at the front of the camera).
      • There are 3 screws on the bottom
      • There is 1 screw on the right side
      댓글 쓰기
    2. Canon PowerShot A550 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Turn to the bottom of the camera.
      • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
      댓글 쓰기
    3. Canon PowerShot A550 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
      • This is what the SD card/battery compartment looks like when opened.
      • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
      댓글 쓰기
    4. Canon PowerShot A550 LCD Screen Replacement: 4 단계, 이미지 2개 중 1개 Canon PowerShot A550 LCD Screen Replacement: 4 단계, 이미지 2개 중 2개
      • Gently remove the front cover away from the camera body.
      • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
      댓글 쓰기
    5. Canon PowerShot A550 LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
      • The camera should look like this once the front cover is removed.
      댓글 쓰기
    6. Canon PowerShot A550 LCD Screen Replacement: 6 단계, 이미지 3개 중 1개 Canon PowerShot A550 LCD Screen Replacement: 6 단계, 이미지 3개 중 2개 Canon PowerShot A550 LCD Screen Replacement: 6 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Start from the battery compartment and remove the back cover.
      • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
      • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
      댓글 쓰기
    7. Canon PowerShot A550 LCD Screen Replacement: 7 단계, 이미지 1개 중 1개
      • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
      댓글 쓰기
    1. Canon PowerShot A550 LCD Screen Replacement, LCD Screen: 8 단계, 이미지 1개 중 1개
      • Use a #00 phillips head screwdriver to remove 2 3.34mm phillips screws holding the LCD screen in place.
      댓글 쓰기
    2. Canon PowerShot A550 LCD Screen Replacement: 9 단계, 이미지 2개 중 1개 Canon PowerShot A550 LCD Screen Replacement: 9 단계, 이미지 2개 중 2개
      • Use an iPod Opening Tool to lift the brown portion of the connector to unlock it.
      • Slide the data cable out of the connector.
      • Caution: Do not force the data cable out of the connector. It may rip!
      댓글 쓰기
    3. Canon PowerShot A550 LCD Screen Replacement: 10 단계, 이미지 1개 중 1개
      • The LCD screen can now be be removed to be fixed/replaced.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Precilla Tang
회원 가입일: 04/19/11
207 평판
안내서 2개를 작성함
Cal Poly, Team 8-6, Regan Spring 2011 Cal Poly, Team 8-6, Regan Spring 2011 회원
CPSU-REGAN-S11S8G6
4 회원들
안내서 22개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 57
전체 시간: 4,249
