주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot A590 IS Clock Battery Replacement
필요한 것
    1. Canon PowerShot A590 IS Clock Battery Replacement, Batteries: 1 단계, 이미지 2개 중 1개 Canon PowerShot A590 IS Clock Battery Replacement, Batteries: 1 단계, 이미지 2개 중 2개
      • The battery hatch is on the bottom of the camera.
      • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
      • While the switch is pushed forward, pull the cover away from the camera.
      댓글 쓰기
    2. Canon PowerShot A590 IS Clock Battery Replacement: 2 단계, 이미지 1개 중 1개
      • This camera requires AA batteries.
      • To remove batteries, simply allow them to fall out of the camera.
      • Use a fingernail to lift the clock battery out of the camera.
      댓글 쓰기
    3. Canon PowerShot A590 IS Clock Battery Replacement: 3 단계, 이미지 1개 중 1개
      • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
      댓글 쓰기
    1. Canon PowerShot A590 IS Clock Battery Replacement, Locate Clock Battery: 4 단계, 이미지 1개 중 1개
      • To access the clock battery, find the clock battery cover, shown here in the red square.
      댓글 쓰기
    2. Canon PowerShot A590 IS Clock Battery Replacement, Remove Battery Tab: 5 단계, 이미지 1개 중 1개
      • When accessing the clock battery, use a fingernail or similar small instrument to gently pull the tab out.
      댓글 쓰기
    3. Canon PowerShot A590 IS Clock Battery Replacement, Remove Battery from Tab: 6 단계, 이미지 1개 중 1개
      • Now that you have the tab and battery removed, use a fingernail or other small tool to remove the battery from the tab.
      • This battery is a CR1220 type watch battery.
      댓글 쓰기
    4. Canon PowerShot A590 IS Clock Battery Replacement, Replacing Clock Battery: 7 단계, 이미지 1개 중 1개
      • When replacing the clock battery, be sure to have the battery oriented properly, as shown in the picture.
      • Remember, the tab goes in with the exposed side of the battery facing towards the lens.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 13명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Matt Wolfe
회원 가입일: 10/11/10
411 평판
안내서 1개를 작성함
Cal Poly, Team 9-19, Regan Fall 2010 Cal Poly, Team 9-19, Regan Fall 2010 회원
CPSU-REGAN-F10S9G19
4 회원들
안내서 21개를 작성함
9가이드 댓글
thanks its very useful forme
srikrishnan2003 - 답글 공유
thank you, very useful for my old camera :)
agungsp2000 - 답글 공유
Perfect! I never even knew I had this battery in there. Couldn't figure out why the date and time wouldn't stay set every time I shut it off. And then I found the answer here.
Thank you very much for the post!
sherlock261 - 답글 공유
I'm a senior citizen and am not very good with modern technology. Been going crazy trying to set my clock in my digital camera. I didn't want to buy a new one because I have had this one for years (Power Shot A590) and didn't want to have to learn to use a newer one. Finally got smart enough to do a google search for an answer. Will get a new battery tomorrow and solve my problem. Thanks for the help!...the information age is good for something after all.
Pat Solomon - 답글 공유
Wow this is a great site. I got the answer I needed right away. The instructions were clear, simple and correct. Thank you.
You are bookmarked.
jeffrey wales - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 74
전체 시간: 17,666
