주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot A620 Camera Housing Replacement
필요한 것
    1. Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: 1 단계, 이미지 3개 중 1개 Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: 1 단계, 이미지 3개 중 2개 Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: 1 단계, 이미지 3개 중 3개
      • Slide the tab on the battery door while pushing the battery door away from you. The battery door should pop open.
      댓글 쓰기
    2. Canon PowerShot A620 Camera Housing Replacement, Insert Batteries: 2 단계, 이미지 2개 중 1개 Canon PowerShot A620 Camera Housing Replacement, Insert Batteries: 2 단계, 이미지 2개 중 2개
      • Insert AA batteries according to the diagram printed on the camera.
      • Close the battery door.
      댓글 쓰기
    1. Canon PowerShot A620 Camera Housing Replacement, Side Panel: 3 단계, 이미지 3개 중 1개 Canon PowerShot A620 Camera Housing Replacement, Side Panel: 3 단계, 이미지 3개 중 2개 Canon PowerShot A620 Camera Housing Replacement, Side Panel: 3 단계, 이미지 3개 중 3개
      • Unscrew the three Phillips #00 1.6x3mm screws on the side.
      • Lift loose panel from the case.
      • Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
      댓글 쓰기
    2. Canon PowerShot A620 Camera Housing Replacement, Bottom Panel: 4 단계, 이미지 1개 중 1개
      • Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
      댓글 쓰기
    3. Canon PowerShot A620 Camera Housing Replacement, Battery Compartment: 5 단계, 이미지 1개 중 1개
      • Open the battery door.
      • Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
      댓글 쓰기
    4. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: 6 단계, 이미지 2개 중 1개 Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: 6 단계, 이미지 2개 중 2개
      • Lift the terminal cover on the side of the camera.
      • Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
      댓글 쓰기
    5. Canon PowerShot A620 Camera Housing Replacement, Top Panel: 7 단계, 이미지 1개 중 1개
      • Gently pull the top panel to separate it from the case.
      • Although the top panel will now be free from the rest of the case, it will still be attached to the camera by a ribbon cable.
      댓글 쓰기
    6. Canon PowerShot A620 Camera Housing Replacement, Front Panel: 8 단계, 이미지 2개 중 1개 Canon PowerShot A620 Camera Housing Replacement, Front Panel: 8 단계, 이미지 2개 중 2개
      • Gently pull the front panel to separate it from the camera.
      • The battery terminals are easy to access from this step.
      댓글 쓰기
    7. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: 9 단계, 이미지 2개 중 1개 Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: 9 단계, 이미지 2개 중 2개
      • Gently pull the terminal cover to separate it from the camera.
      댓글 쓰기
    8. Canon PowerShot A620 Camera Housing Replacement, Memory Card Cover: 10 단계, 이미지 2개 중 1개 Canon PowerShot A620 Camera Housing Replacement, Memory Card Cover: 10 단계, 이미지 2개 중 2개
      • Slide the memory card cover down.
      • Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
      댓글 쓰기
    9. Canon PowerShot A620 Camera Housing Replacement, Back Panel: 11 단계, 이미지 2개 중 1개 Canon PowerShot A620 Camera Housing Replacement, Back Panel: 11 단계, 이미지 2개 중 2개
      • Gently pull the back panel to separate it from the camera.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jaime Abraham
회원 가입일: 09/08/14
350 평판
안내서 3개를 작성함
CSU Fullerton, Team 1-1, Bruce Fall 2014 CSU Fullerton, Team 1-1, Bruce Fall 2014 회원
CSUF-BRUCE-F14S1G1
3 회원들
안내서 6개를 작성함
1가이드 댓글
Ottima spiegazione: é tutto facile quando la spiegazione é semplice ed univoca. Ma redigere istruzioni semplici é un'arte che non tutti possiedono.
Paolo Ravera - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 21
전체 시간: 2,371
