주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot A630 Trigger Button Replacement
필요한 것
    1. Canon PowerShot A630 Trigger Button Replacement, Front Panel: 1 단계, 이미지 2개 중 1개 Canon PowerShot A630 Trigger Button Replacement, Front Panel: 1 단계, 이미지 2개 중 2개
      • Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera.
      • Remove batteries.
      댓글 쓰기
    2. Canon PowerShot A630 Trigger Button Replacement: 2 단계, 이미지 2개 중 1개 Canon PowerShot A630 Trigger Button Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the three indicated .2mm screws using a Phillips #00 screwdriver.
      • Gently pull off side-panel to remove it.
      댓글 쓰기
    3. Canon PowerShot A630 Trigger Button Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the two indicated .2mm screws using a Phillips #00 screwdriver.
      댓글 쓰기
    4. Canon PowerShot A630 Trigger Button Replacement: 4 단계, 이미지 2개 중 1개 Canon PowerShot A630 Trigger Button Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the indicated .2mm screw using a Phillips #00 screwdriver.
      • Remove the three .2mm screws located on the internal side of the top panel within the battery chamber using a Phillips #00 screwdriver.
      댓글 쓰기
    5. Canon PowerShot A630 Trigger Button Replacement: 5 단계, 이미지 2개 중 1개 Canon PowerShot A630 Trigger Button Replacement: 5 단계, 이미지 2개 중 2개
      • Open 'DIGITAL A/V OUT' door on camera.
      댓글 쓰기
    6. Canon PowerShot A630 Trigger Button Replacement: 6 단계, 이미지 1개 중 1개
      • Grip the sides of the top panel and gently pull to separate the top panel from the camera body.
      • The top panel will not completely detach.
      댓글 쓰기
    7. Canon PowerShot A630 Trigger Button Replacement: 7 단계, 이미지 2개 중 1개 Canon PowerShot A630 Trigger Button Replacement: 7 단계, 이미지 2개 중 2개
      • Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels.
      • Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
      댓글 쓰기
    1. Canon PowerShot A630 Trigger Button Replacement, Trigger Button: 8 단계, 이미지 1개 중 1개
      • Use the spudger to gently pull back the retaining clip and pull the ribbon out
      • The top panel should now be completely detached from the camera
      • Applying to much force to the spudger may damage the retaining clip
      댓글 쓰기
    2. Canon PowerShot A630 Trigger Button Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the two screws holding down the metal frame using the Phillips #00 screwdriver
      댓글 쓰기
    3. Canon PowerShot A630 Trigger Button Replacement: 10 단계, 이미지 1개 중 1개
      • Lift up the metal frame to expose the two screws located under the trigger button.
      • Remove the two screws using Phillips #00 screwdriver
      댓글 쓰기
    4. Canon PowerShot A630 Trigger Button Replacement: 11 단계, 이미지 2개 중 1개 Canon PowerShot A630 Trigger Button Replacement: 11 단계, 이미지 2개 중 2개
      • Trigger button should fall out
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kelly Duggan
회원 가입일: 10/13/14
460 평판
안내서 3개를 작성함
Clemson, Team 2-5, Benson Fall 2014 Clemson, Team 2-5, Benson Fall 2014 회원
CLEM-BENSON-F14S2G5
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 28
전체 시간: 1,051
