주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot A80 Flash Assembly Replacement
필요한 것
    1. Canon PowerShot A80 Flash Assembly Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Remove the three Phillips #00 screws from the bottom of the camera.
      댓글 쓰기
    2. Canon PowerShot A80 Flash Assembly Replacement: 2 단계, 이미지 2개 중 1개 Canon PowerShot A80 Flash Assembly Replacement: 2 단계, 이미지 2개 중 2개
      • Open the door to the CompactFlash memory card slot by sliding it towards you and swinging it open.
      • Remove the memory card if it is still in the camera.
      • Use the Phillips #00 screwdriver to remove the single screw underneath the memory card slot door.
      댓글 쓰기
    3. Canon PowerShot A80 Flash Assembly Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the Phillips #00 screw located inside the top of the memory card compartment.
      댓글 쓰기
    4. Canon PowerShot A80 Flash Assembly Replacement: 4 단계, 이미지 2개 중 1개 Canon PowerShot A80 Flash Assembly Replacement: 4 단계, 이미지 2개 중 2개
      • Open the battery compartment door at the bottom of the camera by sliding the latch to the right and then sliding the door down.
      • Remove the batteries from the compartment.
      • Remove the three Phillips #00 screws located inside the battery compartment.
      • The screw on the left is longer than the other two.
      댓글 쓰기
    5. Canon PowerShot A80 Flash Assembly Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the top lid of the camera.
      • Be cautious of the fragile mylar cable that connects the lid to the main body of the camera.
      • Removing the lid takes a little force. Do this gently. There may be a snapping sound.
      • The door to the memory card compartment will be freed and should be removable now.
      • In other versions of this camera, there is a tab that secures the top from the wrist strap. If yours has this, you won't be able to completely separate the top until you have removed the top screw in Step 8.
      댓글 쓰기
    6. Canon PowerShot A80 Flash Assembly Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the two Phillips #00 screws from the side of the camera.
      • Open the small rubber door below this screw that covers the connectors.
      댓글 쓰기
    7. Canon PowerShot A80 Flash Assembly Replacement: 7 단계, 이미지 2개 중 1개 Canon PowerShot A80 Flash Assembly Replacement: 7 단계, 이미지 2개 중 2개
      • Open and pivot the LCD screen to its widest open position.
      • Remove the rear cover by pulling it straight away from the body of the camera.
      • When reassembling the camera, remember to replace the screws in the same location from which you removed them. Otherwise, you may damage the camera.
      댓글 쓰기
    1. Canon PowerShot A80 Flash Assembly Replacement, Front Cover: 8 단계, 이미지 1개 중 1개
      • Using a Phillips #00 screwdriver, remove the 3.3 mm long top screw located on the side of the camera. This screw holds the side panels and the front cover together.
      • The side panel may get stuck on the internal wires, so gently wiggle this panel loose.
      댓글 쓰기
    2. Canon PowerShot A80 Flash Assembly Replacement: 9 단계, 이미지 1개 중 1개
      • Gently remove the side panel by pulling it away from the camera.
      댓글 쓰기
    3. Canon PowerShot A80 Flash Assembly Replacement: 10 단계, 이미지 1개 중 1개
      • Using the Phillips #00 screwdriver, unscrew the 2.4 mm long screw that holds on the front panel underneath the side panel.
      댓글 쓰기
    4. Canon PowerShot A80 Flash Assembly Replacement: 11 단계, 이미지 1개 중 1개
      • Underneath the battery cover there is a 3.8 mm screw in the corner. Using the Phillips #00 screwdriver, remove this screw.
      댓글 쓰기
    5. Canon PowerShot A80 Flash Assembly Replacement: 12 단계, 이미지 1개 중 1개
      • Gently pull up on the front cover to remove it from the body.
      댓글 쓰기
    1. Canon PowerShot A80 Flash Assembly Replacement, Flash Assembly: 13 단계, 이미지 1개 중 1개
      • Unscrew the 3.8 mm screw under the flash housing.
      댓글 쓰기
    2. Canon PowerShot A80 Flash Assembly Replacement: 14 단계, 이미지 1개 중 1개
      • Lift up black cover.
      • Black cover is attached to the top of the capacitor with adhesive.
      댓글 쓰기
    3. Canon PowerShot A80 Flash Assembly Replacement: 15 단계, 이미지 1개 중 1개
      • If the entire flash housing needs to be replaced...
      • Unsolder the black and red wires from the back of the circuit board behind the flash.
      댓글 쓰기
    4. Canon PowerShot A80 Flash Assembly Replacement: 16 단계, 이미지 2개 중 1개 Canon PowerShot A80 Flash Assembly Replacement: 16 단계, 이미지 2개 중 2개
      • Use the opening tool to unclip both sides of the black cover on top of the flash
      댓글 쓰기
    5. Canon PowerShot A80 Flash Assembly Replacement: 17 단계, 이미지 1개 중 1개
      • Use the opening tool to lift off the black flash cover.
      댓글 쓰기
    6. Canon PowerShot A80 Flash Assembly Replacement: 18 단계, 이미지 1개 중 1개
      • If the flash needs to to fixed...
      • Unsolder the brown wire from the circuit board.
      • The piece of metal that attaches these parts will have to be bent back.
      • Make sure the capacitor is discharged before these steps are attempted. Do so with a screwdriver with a rubber handle.
      댓글 쓰기
    7. Canon PowerShot A80 Flash Assembly Replacement: 19 단계, 이미지 1개 중 1개
      • Unsolder the gray wire attached to the capacitor.
      • This is the last wire that connects to the flash.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Remember to re-solder any wires that were unsoldered.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
ryne contreras
회원 가입일: 01/28/11
141 평판
안내서 1개를 작성함
Cal Poly, Team 7-31, Regan Winter 2011 Cal Poly, Team 7-31, Regan Winter 2011 회원
CPSU-REGAN-W11S7G31
6 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 42
전체 시간: 3,986
