주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot ELPH 300HS LCD Screen Replacement
필요한 것
      • Before you begin taking apart your device, the first, and MOST IMPORTANT STEPS are to:
      • Turn off your camera.
      • Remove the battery to prevent risk of shock.
      댓글 쓰기
    1. Canon PowerShot ELPH 300HS LCD Screen Replacement, Remove the Battery: 2 단계, 이미지 2개 중 1개 Canon PowerShot ELPH 300HS LCD Screen Replacement, Remove the Battery: 2 단계, 이미지 2개 중 2개
      • Turn off your camera by pressing the power button, located on the top-center of the device.
      • Locate the battery door on the bottom right area of the camera case.
      • Place your finger firmly on the black rubber pad on the battery door and slide the door to the right to open it.
      • Locate the orange battery release button beneath the battery door.
      • Slide the battery release button downward to release the battery.
      댓글 쓰기
    2. Canon PowerShot ELPH 300HS LCD Screen Replacement, Left Side Screws: 3 단계, 이미지 1개 중 1개
      • Be careful when removing screws, as they are stripped easily.
      • Remove the two screws located on the left side of the camera case, using the Phillips screwdriver #00 (2.0 mm).
      댓글 쓰기
    3. Canon PowerShot ELPH 300HS LCD Screen Replacement, Bottom Screws: 4 단계, 이미지 1개 중 1개
      • Remove the two screws on the bottom of the camera located near the battery door (Phillips #00 screwdriver) (4.0 mm).
      댓글 쓰기
    4. Canon PowerShot ELPH 300HS LCD Screen Replacement, Right Side Screws: 5 단계, 이미지 1개 중 1개
      • Remove the screw located on the lower right side of the camera case (Phillips #00 screwdriver) (4.0 mm).
      • Remove the HDMI A/V out port cover located on the upper right side of the camera.
      • Remove the screw located just beneath the port cover removed in step 2. (Phillips #00 screwdriver) (2.0 mm).
      댓글 쓰기
    5. Canon PowerShot ELPH 300HS LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the back portion of the camera case to reveal the screw located on the top of the case.
      • Remove the screw from the top of camera case, located next to the shutter button (Phillips #00 screwdriver) (1.5 mm).
      댓글 쓰기
    6. Canon PowerShot ELPH 300HS LCD Screen Replacement, Remove the Case from the Camera: 7 단계, 이미지 3개 중 1개 Canon PowerShot ELPH 300HS LCD Screen Replacement, Remove the Case from the Camera: 7 단계, 이미지 3개 중 2개 Canon PowerShot ELPH 300HS LCD Screen Replacement, Remove the Case from the Camera: 7 단계, 이미지 3개 중 3개
      • Carefully pry the case apart at the seem, using your fingers.
      • Be careful not to over bend the small metal projections located along the seams. These aid in holding the case together.
      • Be careful not to allow dust or other particles to settle inside of the camera while the case is detached. This can cause functional issues in the future.
      댓글 쓰기
    1. Canon PowerShot ELPH 300HS LCD Screen Replacement, LCD Screen: 8 단계, 이미지 2개 중 1개 Canon PowerShot ELPH 300HS LCD Screen Replacement, LCD Screen: 8 단계, 이미지 2개 중 2개
      • Disconnect the copper ribbon next to the blue port on the motherboard.
      댓글 쓰기
    2. Canon PowerShot ELPH 300HS LCD Screen Replacement: 9 단계, 이미지 3개 중 1개 Canon PowerShot ELPH 300HS LCD Screen Replacement: 9 단계, 이미지 3개 중 2개 Canon PowerShot ELPH 300HS LCD Screen Replacement: 9 단계, 이미지 3개 중 3개
      • Remove the L shaped bracket around the top and right side of the LCD screen.
      댓글 쓰기
    3. Canon PowerShot ELPH 300HS LCD Screen Replacement: 10 단계, 이미지 3개 중 1개 Canon PowerShot ELPH 300HS LCD Screen Replacement: 10 단계, 이미지 3개 중 2개 Canon PowerShot ELPH 300HS LCD Screen Replacement: 10 단계, 이미지 3개 중 3개
      • Insert the flat side of the spudger tool carefully on the top of the LCD screen and lift the screen free.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Kathryn Van Susante
회원 가입일: 02/26/14
697 평판
안내서 5개를 작성함
Michigan Tech, Team 5-6, Lauer Spring 2014 Michigan Tech, Team 5-6, Lauer Spring 2014 회원
MTU-LAUER-S14S5G6
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 17
지난 30일: 77
전체 시간: 5,977
