주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot ELPH 310 HS Lens Replacement
필요한 것
    1. Canon PowerShot ELPH 310 HS Lens  Replacement, External Panels: 1 단계, 이미지 1개 중 1개
      • Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
      • Using your hands, remove the image stabilizer panel.
      댓글 쓰기
    2. Canon PowerShot ELPH 310 HS Lens  Replacement: 2 단계, 이미지 2개 중 1개 Canon PowerShot ELPH 310 HS Lens  Replacement: 2 단계, 이미지 2개 중 2개
      • Unscrew the two 4 mm Phillips head screws from the bottom side of the camera.
      댓글 쓰기
    3. Canon PowerShot ELPH 310 HS Lens  Replacement: 3 단계, 이미지 2개 중 1개 Canon PowerShot ELPH 310 HS Lens  Replacement: 3 단계, 이미지 2개 중 2개
      • Using your hand, open the battery portal located on the bottom left of the camera. The screw is in the bottom left of the battery portal.
      • Unscrew the hidden 4mm Phillips head screw inside the battery portal.
      댓글 쓰기
    4. Canon PowerShot ELPH 310 HS Lens  Replacement: 4 단계, 이미지 2개 중 1개 Canon PowerShot ELPH 310 HS Lens  Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the HDMI side panel with your hands.
      • Unscrew the four 4 mm Phillips head screws from the inside of the camera.
      댓글 쓰기
    5. Canon PowerShot ELPH 310 HS Lens  Replacement: 5 단계, 이미지 1개 중 1개
      • The back side of the camera should pop off or be removed by hand.
      댓글 쓰기
    6. Canon PowerShot ELPH 310 HS Lens  Replacement: 6 단계, 이미지 2개 중 1개 Canon PowerShot ELPH 310 HS Lens  Replacement: 6 단계, 이미지 2개 중 2개
      • Unscrew the one 3 mm Phillips head screw on the top of the camera.
      댓글 쓰기
    7. Canon PowerShot ELPH 310 HS Lens  Replacement: 7 단계, 이미지 1개 중 1개
      • Manually remove the front panel from the camera.
      댓글 쓰기
    1. Canon PowerShot ELPH 310 HS Lens  Replacement, LCD Screen: 8 단계, 이미지 2개 중 1개 Canon PowerShot ELPH 310 HS Lens  Replacement, LCD Screen: 8 단계, 이미지 2개 중 2개
      • Using your hands, remove the metal piece (surrounding the right side of the screen) from the right side of the camera.
      댓글 쓰기
    2. Canon PowerShot ELPH 310 HS Lens  Replacement: 9 단계, 이미지 1개 중 1개
      • Using your hands, lift up the screen.
      • The screen is fragile!
      댓글 쓰기
    3. Canon PowerShot ELPH 310 HS Lens  Replacement: 10 단계, 이미지 3개 중 1개 Canon PowerShot ELPH 310 HS Lens  Replacement: 10 단계, 이미지 3개 중 2개 Canon PowerShot ELPH 310 HS Lens  Replacement: 10 단계, 이미지 3개 중 3개
      • The strip tears easily!
      • Manually lift the shutter button plate and remove the white ZIF connector, which is the white clasp underneath.
      • On the front of the camera, using your fingers, undo the orange ribbon from the gray clasp and pull the ribbon through the shutter deck.
      댓글 쓰기
    1. Canon PowerShot ELPH 310 HS Lens  Replacement, Lens: 11 단계, 이미지 2개 중 1개 Canon PowerShot ELPH 310 HS Lens  Replacement, Lens: 11 단계, 이미지 2개 중 2개
      • On the front motherboard, unscrew the one bottom right 3 mm Phillips head screw.
      댓글 쓰기
    2. Canon PowerShot ELPH 310 HS Lens  Replacement: 12 단계, 이미지 3개 중 1개 Canon PowerShot ELPH 310 HS Lens  Replacement: 12 단계, 이미지 3개 중 2개 Canon PowerShot ELPH 310 HS Lens  Replacement: 12 단계, 이미지 3개 중 3개
      • Unscrew the four 3 mm Phillips head screws attached to the metal casing on the back of the camera, behind where the LCD screen once was.
      댓글 쓰기
    3. Canon PowerShot ELPH 310 HS Lens  Replacement: 13 단계, 이미지 2개 중 1개 Canon PowerShot ELPH 310 HS Lens  Replacement: 13 단계, 이미지 2개 중 2개
      • Using your hands, carefully lift the flash housing up and remove it from the area.
      댓글 쓰기
    4. Canon PowerShot ELPH 310 HS Lens  Replacement: 14 단계, 이미지 1개 중 1개
      • Using a plastic spudger, remove the bottom front ZIF connector.
      댓글 쓰기
    5. Canon PowerShot ELPH 310 HS Lens  Replacement: 15 단계, 이미지 2개 중 1개 Canon PowerShot ELPH 310 HS Lens  Replacement: 15 단계, 이미지 2개 중 2개
      • Using your hands, carefully remove the center ribbon.
      • Manually remove the lens.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sarah Van Putten Vink
회원 가입일: 09/24/15
176 평판
안내서 1개를 작성함
1가이드 댓글
excellent procedure. nice pix too. hint about those fragile flex cables is important, they are thinner than a human hair!
Happy Fixer - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 57
전체 시간: 3,306
