주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot ELPH 310 HS Shutter Button Replacement
필요한 것
    1. Canon PowerShot ELPH 310 HS Shutter Button Replacement, External Panels: 1 단계, 이미지 1개 중 1개
      • Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
      • Using your hands, remove the image stabilizer panel.
      댓글 쓰기
    2. Canon PowerShot ELPH 310 HS Shutter Button Replacement: 2 단계, 이미지 2개 중 1개 Canon PowerShot ELPH 310 HS Shutter Button Replacement: 2 단계, 이미지 2개 중 2개
      • Unscrew the two 4 mm Phillips head screws from the bottom side of the camera.
      댓글 쓰기
    3. Canon PowerShot ELPH 310 HS Shutter Button Replacement: 3 단계, 이미지 2개 중 1개 Canon PowerShot ELPH 310 HS Shutter Button Replacement: 3 단계, 이미지 2개 중 2개
      • Using your hand, open the battery portal located on the bottom left of the camera. The screw is in the bottom left of the battery portal.
      • Unscrew the hidden 4mm Phillips head screw inside the battery portal.
      댓글 쓰기
    4. Canon PowerShot ELPH 310 HS Shutter Button Replacement: 4 단계, 이미지 2개 중 1개 Canon PowerShot ELPH 310 HS Shutter Button Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the HDMI side panel with your hands.
      • Unscrew the four 4 mm Phillips head screws from the inside of the camera.
      댓글 쓰기
    5. Canon PowerShot ELPH 310 HS Shutter Button Replacement: 5 단계, 이미지 1개 중 1개
      • The back side of the camera should pop off or be removed by hand.
      댓글 쓰기
    6. Canon PowerShot ELPH 310 HS Shutter Button Replacement: 6 단계, 이미지 2개 중 1개 Canon PowerShot ELPH 310 HS Shutter Button Replacement: 6 단계, 이미지 2개 중 2개
      • Unscrew the one 3 mm Phillips head screw on the top of the camera.
      댓글 쓰기
    7. Canon PowerShot ELPH 310 HS Shutter Button Replacement: 7 단계, 이미지 1개 중 1개
      • Manually remove the front panel from the camera.
      댓글 쓰기
    1. Canon PowerShot ELPH 310 HS Shutter Button Replacement, Shutter Button: 8 단계, 이미지 1개 중 1개
      • Using your hand, lift and remove the shutter button deck from the top of camera.
      • The front clasp is fragile.
      댓글 쓰기
    2. Canon PowerShot ELPH 310 HS Shutter Button Replacement: 9 단계, 이미지 1개 중 1개
      • Unclip the cables from the front of the motherboard, using your hands.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Brandon
회원 가입일: 09/24/15
101 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 23
전체 시간: 832
