주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot G11 LCD Screen Replacement
필요한 것
    1. Canon PowerShot G11 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1개 중 1개
      • Remove the two 3.10mm Phillips #00 screws from the LCD case.
      댓글 쓰기
    2. Canon PowerShot G11 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Open the LCD screen and turn it so the screen is facing the bottom of the camera, the screw is on the bottom of the LCD screen.
      • Remove the 3.10mm Philips #00 screw from the bottom end of the LCD screen.
      댓글 쓰기
    3. Canon PowerShot G11 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
      • Turn the LCD so that the screen is facing the top of the camera, the screw you need is on the bottom of the LCD screen.
      • Remove the 3.10mm Philips #00 screw.
      댓글 쓰기
    4. Canon PowerShot G11 LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
      • Use the plastic opening tool on the indent at the top of the LCD screen to pop off the LCD case.
      댓글 쓰기
    5. Canon PowerShot G11 LCD Screen Replacement: 5 단계, 이미지 2개 중 1개 Canon PowerShot G11 LCD Screen Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the 2.22mm Phillips #00 screw that is located next to the indent handle.
      • When the top screw is removed the small metal bracket will fall out, when reassembling the LCD screen remember to put it back on.
      댓글 쓰기
    6. Canon PowerShot G11 LCD Screen Replacement: 6 단계, 이미지 2개 중 1개 Canon PowerShot G11 LCD Screen Replacement: 6 단계, 이미지 2개 중 2개
      • Once the back panel is off remove the two 3.13mm Philips #00 screws.
      • There are magnets next the screws so when you reassemble the LCD screen make note of this, they will move the screws.
      댓글 쓰기
    7. Canon PowerShot G11 LCD Screen Replacement: 7 단계, 이미지 2개 중 1개 Canon PowerShot G11 LCD Screen Replacement: 7 단계, 이미지 2개 중 2개
      • On the bottom of the LCD screen carefully turn it so the screen is facing the top of the camera and remove the 2.22mm Phillips #00 screw.
      • Once this screw comes off the top case will come off and the LCD screen will be held by only the wires so handle it carefully so as not to damage the wires.
      댓글 쓰기
    8. Canon PowerShot G11 LCD Screen Replacement: 8 단계, 이미지 3개 중 1개 Canon PowerShot G11 LCD Screen Replacement: 8 단계, 이미지 3개 중 2개 Canon PowerShot G11 LCD Screen Replacement: 8 단계, 이미지 3개 중 3개
      • Remove the screen from the base of the LCD.
      • Do not pull because the wire strip is still attached to the LCD base.
      • Do not remove this wire, it is not needed when replacing the screen.
      댓글 쓰기
    9. Canon PowerShot G11 LCD Screen Replacement: 9 단계, 이미지 3개 중 1개 Canon PowerShot G11 LCD Screen Replacement: 9 단계, 이미지 3개 중 2개 Canon PowerShot G11 LCD Screen Replacement: 9 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Use the tweezers to lift the small brown plastic snap before you remove the wire.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Pablo Martinez
회원 가입일: 01/21/15
163 평판
안내서 1개를 작성함
USF Tampa, Team 5-6, Brown Winter 2015 USF Tampa, Team 5-6, Brown Winter 2015 회원
USFT-BROWN-W15S5G6
3 회원들
안내서 6개를 작성함
4가이드 댓글
Did this. The first time i put it ack together it did not work , Had totake apart and adjust wires okay after put bake together again.
Jim Murphy - 답글 공유
Followed these instructions and the result is excellent. Well done, and thanks very much. Saved me buying another camera!
Steve Rayner - 답글 공유
How do you get a new screen on there?
Jacob Fields - 답글 공유
Faltan planos. Por arte de magia el lcd aparece a la izquierda de varias fotos cuando debería estar debajo de la placa verde. Perdonen, muy mal explicado.
jlmgbaquero007 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 21
지난 30일: 75
전체 시간: 5,935
