주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot G11 Rear Dial Replacement
필요한 것
    1. Canon PowerShot G11 Rear Dial Replacement, Rear Cover: 1 단계, 이미지 1개 중 1개
      • Remove the three screws on the bottom of the camera using the 00 sized phillips head screw driver.
      댓글 쓰기
    2. Canon PowerShot G11 Rear Dial Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the four screws on the left side of the camera.
      댓글 쓰기
    3. Canon PowerShot G11 Rear Dial Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the screw on the right side of the camera.
      댓글 쓰기
    4. Canon PowerShot G11 Rear Dial Replacement: 4 단계, 이미지 1개 중 1개
      • Open up the HDMI port on the right side of the camera. Then remove the screw in the HDMI port.
      댓글 쓰기
    5. Canon PowerShot G11 Rear Dial Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the screw to the right of the view finder on the rear of the camera.
      댓글 쓰기
    6. Canon PowerShot G11 Rear Dial Replacement: 6 단계, 이미지 1개 중 1개
      • Use the spudger to crack open the case.
      댓글 쓰기
    7. Canon PowerShot G11 Rear Dial Replacement: 7 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • The rear case is still attached to the camera with a ribbon cable. The socket has a flip up lid that must be flipped up before the cable can be removed. Use the tweezers to flip the cable attachment up.
      댓글 쓰기
    8. Canon PowerShot G11 Rear Dial Replacement: 8 단계, 이미지 1개 중 1개
      • The rear cover is now unattached from the camera.
      댓글 쓰기
    1. Canon PowerShot G11 Rear Dial Replacement, Rear Dial: 9 단계, 이미지 1개 중 1개
      • Remove the plastic covering of the left side of the rear case interior.
      댓글 쓰기
    2. Canon PowerShot G11 Rear Dial Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the four screws that are now accessible with the removal of the plastic covering them.
      댓글 쓰기
    3. Canon PowerShot G11 Rear Dial Replacement: 11 단계, 이미지 2개 중 1개 Canon PowerShot G11 Rear Dial Replacement: 11 단계, 이미지 2개 중 2개
      • After the screws are removed, pull the metal bracket out of the camera.
      댓글 쓰기
    4. Canon PowerShot G11 Rear Dial Replacement: 12 단계, 이미지 1개 중 1개
      • Push the dial out from the other side of the cover.
      댓글 쓰기
    5. Canon PowerShot G11 Rear Dial Replacement: 13 단계, 이미지 1개 중 1개
      • Remove the dial from the case completely.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Dustin Brinegar
회원 가입일: 01/21/15
715 평판
안내서 4개를 작성함
USF Tampa, Team 5-6, Brown Winter 2015 USF Tampa, Team 5-6, Brown Winter 2015 회원
USFT-BROWN-W15S5G6
3 회원들
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 38
전체 시간: 2,745
