주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot G11 Top Cover Replacement
필요한 것
    1. Canon PowerShot G11 Top Cover Replacement, Front Cover: 1 단계, 이미지 2개 중 1개 Canon PowerShot G11 Top Cover Replacement, Front Cover: 1 단계, 이미지 2개 중 2개
      • Push the button on the bottom right of the camera and then remove the plastic surrounding the lens.
      댓글 쓰기
    2. Canon PowerShot G11 Top Cover Replacement: 2 단계, 이미지 1개 중 1개
      • Use the spudger to pop off front case.
      댓글 쓰기
    3. Canon PowerShot G11 Top Cover Replacement: 3 단계, 이미지 1개 중 1개
      • Pull the loosened cover off and you are finished.
      댓글 쓰기
    1. Canon PowerShot G11 Top Cover Replacement, Top Cover: 4 단계, 이미지 1개 중 1개
      • Once both the front and rear covers are removed, disconnect this ribbon cable by flipping it up and disconnecting it.
      댓글 쓰기
    2. Canon PowerShot G11 Top Cover Replacement: 5 단계, 이미지 1개 중 1개
      • Remove these three screws from the rear side of the camera.
      댓글 쓰기
    3. Canon PowerShot G11 Top Cover Replacement: 6 단계, 이미지 1개 중 1개
      • Remove this screw from the front of the camera.
      댓글 쓰기
    4. Canon PowerShot G11 Top Cover Replacement: 7 단계, 이미지 1개 중 1개
      • Disconnect this cable from the motherboard by sliding it in the direction of the cable (toward the top of the camera).
      댓글 쓰기
    5. Canon PowerShot G11 Top Cover Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the top cover and you are finished.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Dustin Brinegar
회원 가입일: 01/21/15
715 평판
안내서 4개를 작성함
USF Tampa, Team 5-6, Brown Winter 2015 USF Tampa, Team 5-6, Brown Winter 2015 회원
USFT-BROWN-W15S5G6
3 회원들
안내서 16개를 작성함
1가이드 댓글
In step 5, it is only necessary to take out the 2 SST screws at ~ 10 and 3 o’clock. The grey screw at 7 stays with the body.
In step 7, you need to SLIDE the connector toward the top of the camera toward the dial. The tweezers in the photo are moving LEFT, not toward the viewer as I interpreted it. If you lift it up as if to disconnect a socket (like in step 4) away from the mother board with tweezers, you’ll easily destroy the delicate connector (as I found out).
Dimwit - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 36
전체 시간: 2,084
