주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot G12 Rear Function Setting Dial Replacement
필요한 것
  1. Canon PowerShot G12 Rear Function Setting Dial Replacement, Rear Function Setting Dial: 1 단계, 이미지 1개 중 1개
    • Remove the three screws on the bottom of the camera using a Phillips-head 00 screwdriver.
    댓글 쓰기
  2. Canon PowerShot G12 Rear Function Setting Dial Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all of the screws on both the left and right side of the camera.
    댓글 쓰기
  3. Canon PowerShot G12 Rear Function Setting Dial Replacement: 3 단계, 이미지 1개 중 1개
    • Looking at the front side of the camera, there is a port on left side of the camera labeled HDMI.
    • Remove the one screw on the side of the HDMI port.
    댓글 쓰기
  4. Canon PowerShot G12 Rear Function Setting Dial Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the screw on the right side of the view finder on the back side of the camera.
    댓글 쓰기
  5. Canon PowerShot G12 Rear Function Setting Dial Replacement: 5 단계, 이미지 1개 중 1개
    • Using a spudger, carefully pry open the back side of the camera starting directly under the camera's serial label.
    • Make sure all sides of the back case are loose before trying to force it off of the camera. It should be removed with relatively little effort.
    댓글 쓰기
  6. Canon PowerShot G12 Rear Function Setting Dial Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • The back case is still attached to the camera with a yellow ribbon cable. The socket has a black flip-up lid that must be flipped up before the cable can be removed. Use precision tweezers to remove the cable.
    댓글 쓰기
  7. Canon PowerShot G12 Rear Function Setting Dial Replacement: 7 단계, 이미지 1개 중 1개
    • Put the camera aside and look to the interior to the camera's back shell.
    • Peel off the thick, plastic seal over the metal plate near the yellow ribbon cable.
    댓글 쓰기
  8. Canon PowerShot G12 Rear Function Setting Dial Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the four screws from the metal plate using a Phillips-head 00 screwdriver.
    댓글 쓰기
  9. Canon PowerShot G12 Rear Function Setting Dial Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the spring from its socket using precision tweezers allowing the metal plate with the function dial to be removed.
    댓글 쓰기
  10. Canon PowerShot G12 Rear Function Setting Dial Replacement: 10 단계, 이미지 1개 중 1개
    • Using precision tweezers, pry the old function dial out of its socket leaving only a black, metal ring attached.
    댓글 쓰기
  11. Canon PowerShot G12 Rear Function Setting Dial Replacement: 11 단계, 이미지 1개 중 1개
    • Attach the new function dial simply by pressing it into the black, metal ring until you hear a click.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alexandra Millett
회원 가입일: 02/23/15
353 평판
안내서 2개를 작성함
USF Tampa, Team 1-5, Leahy Winter 2015 USF Tampa, Team 1-5, Leahy Winter 2015 회원
USFT-LEAHY-W15S1G5
3 회원들
안내서 6개를 작성함
2가이드 댓글
Thank you so much!! I needed to replace the entire rear cover, because Canon doesn't sale just the wheel separately. your guide was the best one I found on the web. I think you ought to make a video of it, I admit I didn't see the "black flip-up" in part 6 so that part (putting the cable back in) was the most aggravating part for me.
But again thank you so much!
Maya Shemolewitz - 답글 공유
Very good guide, the only one I’ve seen so far. Thanks for that>
Philip Knowles
Philip Knowles - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 13
지난 30일: 52
전체 시간: 4,204
