주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot S400 LCD Screen Replacement
필요한 것
    1. Canon PowerShot S400 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 2개 중 1개 Canon PowerShot S400 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 2개 중 2개
      • Unless stated otherwise, use a Phillips #00 screwdriver to remove all screws.
      • On the backside of the camera, remove the 4.75 mm screw that sits at the top right corner.
      • Remove the four 4.75 mm screws that sit at the bottom of the camera.
      댓글 쓰기
    2. Canon PowerShot S400 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
      • On the side of the camera, remove the two 4.75 mm screws that sit near the USB digital terminal.
      댓글 쓰기
    3. Canon PowerShot S400 LCD Screen Replacement: 3 단계, 이미지 3개 중 1개 Canon PowerShot S400 LCD Screen Replacement: 3 단계, 이미지 3개 중 2개 Canon PowerShot S400 LCD Screen Replacement: 3 단계, 이미지 3개 중 3개
      • On the side of the camera, remove the four 4.75 mm screws that sit near the wrist strap mount.
      • Remove the two small metal plates, which the four screws hold in place.
      댓글 쓰기
    4. Canon PowerShot S400 LCD Screen Replacement: 4 단계, 이미지 2개 중 1개 Canon PowerShot S400 LCD Screen Replacement: 4 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • When removing the casing, do not drop the small black plastic piece. This piece sits in a small gap above the lens, to the left of the flash, and underneath the camera case.
      • Remove the small black plastic piece and set it aside. If necessary, use tweezers to remove the small black plastic piece.
      • Detach the front case and back case.
      댓글 쓰기
    5. Canon PowerShot S400 LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
      • Do not remove the metal plate this step refers to. Removal at this step may damage the ribbon cable. Wait until the next step to remove the plate.
      • Remove the 3.5 mm screw that sits on the metal plate at the bottom of the camera.
      • Remove the two other 3.5 mm screws that sit on the side, to the left of the screw you just removed.
      • In the image, we have already removed some of the screws.
      댓글 쓰기
    6. Canon PowerShot S400 LCD Screen Replacement: 6 단계, 이미지 3개 중 1개 Canon PowerShot S400 LCD Screen Replacement: 6 단계, 이미지 3개 중 2개 Canon PowerShot S400 LCD Screen Replacement: 6 단계, 이미지 3개 중 3개
      • A ribbon cable attaches to the metal plate and to the main circuit board, on the front of the camera.
      • Gently release the black latch.
      • Remove the ribbon cable and metal plate assembly.
      댓글 쓰기
    7. Canon PowerShot S400 LCD Screen Replacement: 7 단계, 이미지 2개 중 1개 Canon PowerShot S400 LCD Screen Replacement: 7 단계, 이미지 2개 중 2개
      • On the backside of the camera, remove the 3.5 mm screw that sits to the left of the viewfinder and above the LCD screen.
      • Remove the second 3.5 mm screw that sits directly above the LCD screen.
      • Gently detach the ribbon cable.
      댓글 쓰기
    8. Canon PowerShot S400 LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
      • Locate the ribbon cable on the main circuit board, which sits below the lens.
      • Gently release the black latch on the ribbon cable connector and detach the ribbon cable.
      댓글 쓰기
    9. Canon PowerShot S400 LCD Screen Replacement: 9 단계, 이미지 2개 중 1개 Canon PowerShot S400 LCD Screen Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the LCD screen and set it aside.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Ross Bryan
회원 가입일: 01/21/11
375 평판
안내서 3개를 작성함
Cal Poly, Team 5-19, Amido Winter 2011 Cal Poly, Team 5-19, Amido Winter 2011 회원
CPSU-AMIDO-W11S5G19
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 46
전체 시간: 3,823
