주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot S400 SD Card Slot Replacement
필요한 것
    1. Canon PowerShot S400 SD Card Slot Replacement, SD Card Slot: 1 단계, 이미지 2개 중 1개 Canon PowerShot S400 SD Card Slot Replacement, SD Card Slot: 1 단계, 이미지 2개 중 2개
      • Unless otherwise stated,a #00 philips screwdriver will be used to remove screws.
      • Remove the 4.75mm screw located in the top right corner of the backside of the camera.
      • Remove the four 4.75mm screws located on the bottom of the camera.
      댓글 쓰기
    2. Canon PowerShot S400 SD Card Slot Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the two 4.75mm screws located on the right side of the camera.(the side with the USB adaption plug)
      댓글 쓰기
    3. Canon PowerShot S400 SD Card Slot Replacement: 3 단계, 이미지 3개 중 1개 Canon PowerShot S400 SD Card Slot Replacement: 3 단계, 이미지 3개 중 2개 Canon PowerShot S400 SD Card Slot Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the four 4.75mm screws on the left side of the camera.
      • This will release two small metal plates. Remove these plate.
      댓글 쓰기
    4. Canon PowerShot S400 SD Card Slot Replacement: 4 단계, 이미지 1개 중 1개
      • Only remove the back case.
      • The memory card is held in the metal case located to the right of the LCD screen.
      • Remove the stuck memory card.
      • If you still cannot remove the stuck memory card, proceed with further instructions. If you could remove the memory card then you are done
      댓글 쓰기
    5. Canon PowerShot S400 SD Card Slot Replacement: 5 단계, 이미지 2개 중 1개 Canon PowerShot S400 SD Card Slot Replacement: 5 단계, 이미지 2개 중 2개
      • There is a small black plastic piece that sits above the lens underneath the camera case. This plastic piece may fall out when you remove the cases; recover the piece and save it.
      • Separate the front casing from the camera
      댓글 쓰기
    6. Canon PowerShot S400 SD Card Slot Replacement: 6 단계, 이미지 2개 중 1개 Canon PowerShot S400 SD Card Slot Replacement: 6 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • If the small plastic piece described in the previous step did not fall out, remove it now. The piece is located in a small gap above the lens and to the left of the flash.
      • Removing this piece may require the use of tweezers.
      댓글 쓰기
    7. Canon PowerShot S400 SD Card Slot Replacement: 7 단계, 이미지 2개 중 1개 Canon PowerShot S400 SD Card Slot Replacement: 7 단계, 이미지 2개 중 2개
      • Locate and remove the three 3.45mm screws on the backside of the camera securing the CF card slot.
      • Do not remove ribbon cable. It is not necessary to remove
      • Without removing the ribbon cable, gently remove the memory card.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
14다른 기여자 명과 함께
Adam Grijalva
회원 가입일: 01/20/11
202 평판
안내서 2개를 작성함
Cal Poly, Team 5-19, Amido Winter 2011 Cal Poly, Team 5-19, Amido Winter 2011 회원
CPSU-AMIDO-W11S5G19
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 18
지난 30일: 54
전체 시간: 4,738
