주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot S50 Left Motherboard Replacement
필요한 것
    1. Canon PowerShot S50 Left Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Canon PowerShot S50 Left Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Place camera LCD side up and press up on the battery door.
      • Let it swing open until you can see the battery inside.
      댓글 쓰기
    2. Canon PowerShot S50 Left Motherboard Replacement: 2 단계, 이미지 1개 중 1개
      • Press down on the orange plastic.
      • This will gently eject the battery from its compartment.
      댓글 쓰기
    3. Canon PowerShot S50 Left Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Canon PowerShot S50 Left Motherboard Replacement: 3 단계, 이미지 2개 중 2개
      • Holding the edges, slide out the battery.
      댓글 쓰기
    1. Canon PowerShot S50 Left Motherboard Replacement, Front Panel/Battery Door: 4 단계, 이미지 1개 중 1개
      • Look at the camera from the side with the lanyard and 4 screws.
      • Remove the two 3.4 mm screws on the metallic colored part.
      댓글 쓰기
    2. Canon PowerShot S50 Left Motherboard Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the 3mm screw on the top left.
      • NOTE: When reassembling, it is helpful to put the top screw back in before placing the front cover back on the camera.
      • Now remove the 5.3mm screw on the bottom.
      댓글 쓰기
    3. Canon PowerShot S50 Left Motherboard Replacement: 6 단계, 이미지 1개 중 1개
      • Place the camera LCD side down.
      • Remove the two 5.3mm screws by the battery door.
      댓글 쓰기
    4. Canon PowerShot S50 Left Motherboard Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the four 3.4mm screws on the bottom of the camera around the tripod mount.
      • Make sure to keep these screws separate from the previous 5.3 mm screws.
      댓글 쓰기
    5. Canon PowerShot S50 Left Motherboard Replacement: 8 단계, 이미지 1개 중 1개
      • Stand the camera back up.
      • Remove the two 3.6mm screws on the side with the A/V Out port.
      댓글 쓰기
    6. Canon PowerShot S50 Left Motherboard Replacement: 9 단계, 이미지 1개 중 1개
      • Lift open the rubber flap covering the A/V Out port.
      • Remove the 3.4mm screw in the center.
      • During reassembly, put the A/V out rubber door on before replacing the front panel of the camera
      댓글 쓰기
    7. Canon PowerShot S50 Left Motherboard Replacement: 10 단계, 이미지 1개 중 1개
      • Use a spudger and gently open up the front panel of the camera.
      • A thin plastic ribbon will stay connected by a brown piece to front panel of the camera.
      댓글 쓰기
    8. Canon PowerShot S50 Left Motherboard Replacement: 11 단계, 이미지 1개 중 1개
      • There will be a brown plastic piece keeping the thin plastic ribbon in place.
      • Use the spudger to pull out the brown plastic piece attached to the orange plastic.
      댓글 쓰기
    9. Canon PowerShot S50 Left Motherboard Replacement: 12 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use a pair of tweezers and remove the metal piece inside the camera.
      댓글 쓰기
    10. Canon PowerShot S50 Left Motherboard Replacement: 13 단계, 이미지 1개 중 1개
      • Remove the battery door
      • NOTE: Putting this back on requires aligning the spring on the back of the door with the hole on the camera
      댓글 쓰기
    1. Canon PowerShot S50 Left Motherboard Replacement, Left Motherboard: 14 단계, 이미지 1개 중 1개
      • Disconnect the black and red cable on the left side of the lens.
      댓글 쓰기
    2. Canon PowerShot S50 Left Motherboard Replacement: 15 단계, 이미지 1개 중 1개
      • Disconnect the two orange ribbons on the front of the mother board.
      댓글 쓰기
    3. Canon PowerShot S50 Left Motherboard Replacement: 16 단계, 이미지 1개 중 1개
      • Pull off the orange ribbon on the upper left of the motherboard.
      • This will become available only after removing the ribbon on top.
      • Remove the other two orange ribbons on the middle of the left motherboard.
      댓글 쓰기
    4. Canon PowerShot S50 Left Motherboard Replacement: 17 단계, 이미지 1개 중 1개
      • Remove the 3.3mm screw halfway up the left side of the motherboard just to the left of the lens.
      • Go under the piece of plastic and remove the 2.6mm screw.
      댓글 쓰기
    5. Canon PowerShot S50 Left Motherboard Replacement: 18 단계, 이미지 2개 중 1개 Canon PowerShot S50 Left Motherboard Replacement: 18 단계, 이미지 2개 중 2개
      • Unplug the top part of the left motherboard.
      • Gently lift the left motherboard up to remove
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Jacob
회원 가입일: 03/29/12
16 평판
안내서 3개를 작성함
Cal Poly, Team 7-34, Maness Spring 2012 Cal Poly, Team 7-34, Maness Spring 2012 회원
CPSU-MANESS-S12S7G34
5 회원들
안내서 71개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 46
전체 시간: 1,726
