주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot S500 AV Port Replacement
필요한 것
    1. Canon PowerShot S500 AV Port Replacement, Front and Rear Casing : 1 단계, 이미지 2개 중 1개 Canon PowerShot S500 AV Port Replacement, Front and Rear Casing : 1 단계, 이미지 2개 중 2개
      • Unscrew five Phillips screws using a #0 Phillips screwdriver.
      • One screw is on upper right corner of the back panel.
      • The other four screws are on the bottom of the camera.
      댓글 쓰기
    2. Canon PowerShot S500 AV Port Replacement: 2 단계, 이미지 1개 중 1개
      • Open the memory card cover by moving the slide switch toward the top end of of the camera.
      • Remove the memory card from the slot.
      댓글 쓰기
    3. Canon PowerShot S500 AV Port Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the rear cover from the rest of the camera.
      • This may require gentle rocking of the case to free it.
      댓글 쓰기
    4. Canon PowerShot S500 AV Port Replacement: 4 단계, 이미지 2개 중 1개 Canon PowerShot S500 AV Port Replacement: 4 단계, 이미지 2개 중 2개
      • Unscrew the four Phillips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver.
      댓글 쓰기
    5. Canon PowerShot S500 AV Port Replacement: 5 단계, 이미지 1개 중 1개
      • Free the front cover from the rest of the camera.
      • The cover may require gentle rocking to remove.
      댓글 쓰기
    1. Canon PowerShot S500 AV Port Replacement, LCD: 6 단계, 이미지 1개 중 1개
      • Unscrew two Phillips screws above the LCD using a #0 Phillips screwdriver.
      댓글 쓰기
    2. Canon PowerShot S500 AV Port Replacement: 7 단계, 이미지 1개 중 1개
      • Gently separate the top of LCD from the rest of the camera using your thumb.
      • Be careful not pull the LCD too far because of the ribbon cable connection.
      • Place the Spudger in the hole of the electrical ribbon.
      • Gently pull the ribbon down using the Spudger until it is free from the camera but still connected to the LCD.
      • The LCD will still be connected to the rest of the camera
      댓글 쓰기
    3. Canon PowerShot S500 AV Port Replacement: 8 단계, 이미지 2개 중 1개 Canon PowerShot S500 AV Port Replacement: 8 단계, 이미지 2개 중 2개
      • Unscrew single Phillips screw with a #0 Phillips screwdriver.
      • Free the bottom panel and attached ribbon from the rest of the camera.
      • Be careful not to damage the ribbon.
      댓글 쓰기
    4. Canon PowerShot S500 AV Port Replacement: 9 단계, 이미지 1개 중 1개
      • Turn over the camera.
      • Lift the clear plastic from the face of the camera, peeling the adhesive just below the zoom lens.
      • The plastic will still be connected on the left side.
      댓글 쓰기
    5. Canon PowerShot S500 AV Port Replacement: 10 단계, 이미지 1개 중 1개
      • Place the Spudger between the orange ribbon and the black ribbon gate.
      • Lift the ribbon gate using the Spudger.
      댓글 쓰기
    6. Canon PowerShot S500 AV Port Replacement: 11 단계, 이미지 1개 중 1개
      • Place the Spudger in the corner of the ribbon above the hole.
      • Remove the ribbon from the ribbon gate by pulling the Spudger away from the gate.
      댓글 쓰기
    7. Canon PowerShot S500 AV Port Replacement: 12 단계, 이미지 1개 중 1개
      • Free this ribbon and the bottom panel from the rest of the camera.
      댓글 쓰기
    8. Canon PowerShot S500 AV Port Replacement: 13 단계, 이미지 1개 중 1개
      • Turn the camera over so you can see the LCD.
      • Remove single Phillips screw below the LCD using a #0 Phillips screwdriver.
      댓글 쓰기
    9. Canon PowerShot S500 AV Port Replacement: 14 단계, 이미지 1개 중 1개
      • Lift the blue ribbon gate using the Spudger.
      댓글 쓰기
    10. Canon PowerShot S500 AV Port Replacement: 15 단계, 이미지 1개 중 1개
      • Insert the Spudger into the hole of the ribbon.
      • Move the Spudger away from the gate to fully remove ribbon.
      댓글 쓰기
    11. Canon PowerShot S500 AV Port Replacement: 16 단계, 이미지 1개 중 1개
      • Lift the LCD away from the rest of the camera.
      댓글 쓰기
    1. Canon PowerShot S500 AV Port Replacement, Logic Board: 17 단계, 이미지 2개 중 1개 Canon PowerShot S500 AV Port Replacement, Logic Board: 17 단계, 이미지 2개 중 2개
      • Lift off the capture button by wiggling it back and forth while pulling upward.
      • Be careful not to damage the two clips.
      댓글 쓰기
    2. Canon PowerShot S500 AV Port Replacement: 18 단계, 이미지 2개 중 1개 Canon PowerShot S500 AV Port Replacement: 18 단계, 이미지 2개 중 2개
      • Flip open the four ribbon gates using the Spudger.
      • Gently pull out the ribbon cables from the gates using the Spudger.
      댓글 쓰기
    3. Canon PowerShot S500 AV Port Replacement: 19 단계, 이미지 1개 중 1개
      • Unscrew the four Phillips screws using a #0 Phillips screwdriver.
      댓글 쓰기
    4. Canon PowerShot S500 AV Port Replacement: 20 단계, 이미지 2개 중 1개 Canon PowerShot S500 AV Port Replacement: 20 단계, 이미지 2개 중 2개
      • Gently lift the logic board.
      • Be careful not to pull too hard and damage the white ribbon cable.
      • Place the Spudger so that it is between the logic board, the white ribbon cable, and the rest of the camera.
      • Remove the white ribbon cable by pulling the Spudger away from the camera, keeping it parallel to the logic board.
      댓글 쓰기
    5. Canon PowerShot S500 AV Port Replacement: 21 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Lay the logic board back down so that it is resting on the body of the camera.
      • Pull the two plugs (white and green) out to the right from the logic board using the tweezers.
      댓글 쓰기
    6. Canon PowerShot S500 AV Port Replacement: 22 단계, 이미지 2개 중 1개 Canon PowerShot S500 AV Port Replacement: 22 단계, 이미지 2개 중 2개
      • We're now ready to begin the desoldering process. You'll need a soldering iron, solder, and desoldering wick. You should be able to find these items at a Radio Shack if you don't already have them.
      • Please do not perform this step if you are not comfortable or have previous experience with soldering. Doing so, could cause severe damage to your camera.
      • Desolder the two soldered ribbon cables attached to the logic board.
      댓글 쓰기
    7. Canon PowerShot S500 AV Port Replacement: 23 단계, 이미지 1개 중 1개
      • Free the logic board from the rest of the camera.
      댓글 쓰기
    1. Canon PowerShot S500 AV Port Replacement, AV Port: 24 단계, 이미지 1개 중 1개
      • Pick up the Logic Board
      댓글 쓰기
    2. Canon PowerShot S500 AV Port Replacement: 25 단계, 이미지 2개 중 1개 Canon PowerShot S500 AV Port Replacement: 25 단계, 이미지 2개 중 2개
      • Blow the Particles out of the AV Port or USB Port using compressed air.
      • If the pins are damaged or missing, flip over the logic board and desolder the component from the logic board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Nathan Balcom
회원 가입일: 01/21/10
102 평판
안내서 8개를 작성함
Cal Poly, Team 16-28, Maness Winter 2010 Cal Poly, Team 16-28, Maness Winter 2010 회원
CPSU-MANESS-W10S16G28
4 회원들
안내서 17개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 35
전체 시간: 3,506
