주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot SD1200 IS Function Button Board Replacement
필요한 것
    1. Canon PowerShot SD1200 IS Function Button Board Replacement, Front and Rear Covers: 1 단계, 이미지 1개 중 1개
      • Remove the battery.
      댓글 쓰기
    2. Canon PowerShot SD1200 IS Function Button Board Replacement: 2 단계, 이미지 3개 중 1개 Canon PowerShot SD1200 IS Function Button Board Replacement: 2 단계, 이미지 3개 중 2개 Canon PowerShot SD1200 IS Function Button Board Replacement: 2 단계, 이미지 3개 중 3개
      • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
      • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
      • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
      댓글 쓰기
    3. Canon PowerShot SD1200 IS Function Button Board Replacement: 3 단계, 이미지 2개 중 1개 Canon PowerShot SD1200 IS Function Button Board Replacement: 3 단계, 이미지 2개 중 2개
      • Pull off the front cover.
      • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
      • Remove the back cover.
      댓글 쓰기
    1. Canon PowerShot SD1200 IS Function Button Board Replacement, Function Buttons: 4 단계, 이미지 1개 중 1개
      • Use the spudger to lift the tab on the Zero Insertion Force (ZIF) connector located at the top of the function button board.
      • Be sure you are prying up on the hinged retaining flap, not the connector itself.
      • Slide out the ribbon cable from the connector.
      댓글 쓰기
    2. Canon PowerShot SD1200 IS Function Button Board Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the top screw from the function button board. (3.5mm Phillips 00)
      • Remove the bottom screw from the function button board. (2.5mm Phillips 00)
      댓글 쓰기
    3. Canon PowerShot SD1200 IS Function Button Board Replacement: 6 단계, 이미지 1개 중 1개
      • Lift out the function button board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Jeff Casper
회원 가입일: 09/15/16
897 평판
안내서 7개를 작성함
USF Tampa, Team 17-5, Blackwell Fall 2016 USF Tampa, Team 17-5, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S17G5
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 21
전체 시간: 567
