주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot SD500 Digital ELPH Button Contact Panel Replacement
필요한 것
    1. Canon PowerShot SD500 Digital ELPH Button Contact Panel Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Slide open the battery cover.
      • Push the small orange tab to the side so the battery can be removed.
      댓글 쓰기
    2. Canon PowerShot SD500 Digital ELPH Button Contact Panel Replacement: 2 단계, 이미지 2개 중 1개 Canon PowerShot SD500 Digital ELPH Button Contact Panel Replacement: 2 단계, 이미지 2개 중 2개
      • Slide the battery out of the battery compartment.
      댓글 쓰기
    1. Canon PowerShot SD500 Digital ELPH Button Contact Panel Replacement, Front and Rear Casing: 3 단계, 이미지 2개 중 1개 Canon PowerShot SD500 Digital ELPH Button Contact Panel Replacement, Front and Rear Casing: 3 단계, 이미지 2개 중 2개
      • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
      • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
      • When looking at the back of the camera, these two screws are on the right panel of the camera.
      댓글 쓰기
    2. Canon PowerShot SD500 Digital ELPH Button Contact Panel Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the right side cover from the camera casing.
      댓글 쓰기
    3. Canon PowerShot SD500 Digital ELPH Button Contact Panel Replacement: 5 단계, 이미지 1개 중 1개
      • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
      댓글 쓰기
    4. Canon PowerShot SD500 Digital ELPH Button Contact Panel Replacement: 6 단계, 이미지 1개 중 1개
      • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
      댓글 쓰기
    5. Canon PowerShot SD500 Digital ELPH Button Contact Panel Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the left side cover from the camera.
      댓글 쓰기
    6. Canon PowerShot SD500 Digital ELPH Button Contact Panel Replacement: 8 단계, 이미지 1개 중 1개
      • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
      댓글 쓰기
    7. Canon PowerShot SD500 Digital ELPH Button Contact Panel Replacement: 9 단계, 이미지 2개 중 1개 Canon PowerShot SD500 Digital ELPH Button Contact Panel Replacement: 9 단계, 이미지 2개 중 2개
      • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
      • Remove the internal camera components and layout out all pieces on a clean surface.
      • The front and back cover may require gentle rocking to remove.
      댓글 쓰기
    1. Canon PowerShot SD500 Digital ELPH Button Contact Panel Replacement, Button Contact Panel: 10 단계, 이미지 1개 중 1개
      • Carefully wedge the pry tool under the ribbon in the ribbon gate.
      • Gently remove the ribbon from the ribbon gate by pulling it away from the gate with the pry tool.
      • Be careful not to damage the ribbon.
      댓글 쓰기
    2. Canon PowerShot SD500 Digital ELPH Button Contact Panel Replacement: 11 단계, 이미지 1개 중 1개
      • Gently press the ribbon back to get access to a Phillips screw behind it.
      • Unscrew two .125 inch long Phillips screws using a #00 Philips screwdriver.
      댓글 쓰기
    3. Canon PowerShot SD500 Digital ELPH Button Contact Panel Replacement: 12 단계, 이미지 3개 중 1개 Canon PowerShot SD500 Digital ELPH Button Contact Panel Replacement: 12 단계, 이미지 3개 중 2개 Canon PowerShot SD500 Digital ELPH Button Contact Panel Replacement: 12 단계, 이미지 3개 중 3개
      • Remove the ribbon with a pry tool by gently pulling it out of the ribbon gate tab.
      • Pull the button board away from the rest of the camera.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Taylor Shields
회원 가입일: 10/13/14
861 평판
안내서 8개를 작성함
Clemson, Team 2-1, Benson Fall 2014 Clemson, Team 2-1, Benson Fall 2014 회원
CLEM-BENSON-F14S2G1
4 회원들
안내서 81개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 30
전체 시간: 519
