주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot SD850 IS Camera Lens Replacement
필요한 것
    1. Canon PowerShot SD850 IS Camera Lens Replacement, Case: 1 단계, 이미지 2개 중 1개 Canon PowerShot SD850 IS Camera Lens Replacement, Case: 1 단계, 이미지 2개 중 2개
      • Remove the following 4 screws:
      • Two 2.8 mm Phillips #00 at the bottom of the camera.
      • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
      댓글 쓰기
    2. Canon PowerShot SD850 IS Camera Lens Replacement: 2 단계, 이미지 3개 중 1개 Canon PowerShot SD850 IS Camera Lens Replacement: 2 단계, 이미지 3개 중 2개 Canon PowerShot SD850 IS Camera Lens Replacement: 2 단계, 이미지 3개 중 3개
      • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
      • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
      댓글 쓰기
    3. Canon PowerShot SD850 IS Camera Lens Replacement: 3 단계, 이미지 2개 중 1개 Canon PowerShot SD850 IS Camera Lens Replacement: 3 단계, 이미지 2개 중 2개
      • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
      • Slide light gray door and pull up to open the door.
      • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
      댓글 쓰기
    4. Canon PowerShot SD850 IS Camera Lens Replacement: 4 단계, 이미지 2개 중 1개 Canon PowerShot SD850 IS Camera Lens Replacement: 4 단계, 이미지 2개 중 2개
      • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
      댓글 쓰기
    5. Canon PowerShot SD850 IS Camera Lens Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
      댓글 쓰기
    6. Canon PowerShot SD850 IS Camera Lens Replacement: 6 단계, 이미지 1개 중 1개
      • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
      댓글 쓰기
    1. Canon PowerShot SD850 IS Camera Lens Replacement, LCD Screen: 7 단계, 이미지 1개 중 1개
      • Remove the 1.75 mm Phillips #00 located at the top left of the LCD screen.
      댓글 쓰기
    2. Canon PowerShot SD850 IS Camera Lens Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the two 3.4 mm Phillips #00 located at the bottom of the camera.
      댓글 쓰기
    3. Canon PowerShot SD850 IS Camera Lens Replacement: 9 단계, 이미지 2개 중 1개 Canon PowerShot SD850 IS Camera Lens Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the two metal frames that hold the LCD panel in place.
      댓글 쓰기
    4. Canon PowerShot SD850 IS Camera Lens Replacement: 10 단계, 이미지 1개 중 1개
      • The LCD screen should now only be attached by two LCD data cables.
      • Lift the screen from the left side and use a spudger or a small flat head screwdriver to flip the black portion of the connector upward to unlock it.
      • Carefully slide the data cable out of the connector.
      댓글 쓰기
    5. Canon PowerShot SD850 IS Camera Lens Replacement: 11 단계, 이미지 1개 중 1개
      • The LCD should still be connected by the backlight cable.
      • To remove the backlight cable, use a spudger or a small flat head screwdriver to unlock the backlight cable.
      • Carefully slide out the backlight cable.
      • The LCD screen can now be fully detached from the camera body.
      댓글 쓰기
    6. Canon PowerShot SD850 IS Camera Lens Replacement: 12 단계, 이미지 2개 중 1개 Canon PowerShot SD850 IS Camera Lens Replacement: 12 단계, 이미지 2개 중 2개
      • The LCD screen and housing are now in three pieces:
      • LCD screen
      • LCD screen frame
      • LCD back housing
      • The LCD screen itself can now be removed and fixed/replaced.
      댓글 쓰기
    1. Canon PowerShot SD850 IS Camera Lens Replacement, Flash Unit: 13 단계, 이미지 1개 중 1개
      • Remove the 1.85 mm #00 Phillips located on the left side of the camera.
      댓글 쓰기
    2. Canon PowerShot SD850 IS Camera Lens Replacement: 14 단계, 이미지 2개 중 1개 Canon PowerShot SD850 IS Camera Lens Replacement: 14 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use a set of tweezers to remove the speaker located at the top of the camera on the flash unit.
      • Next use the tweezers to carefully remove the speaker cable off its respective holders.
      댓글 쓰기
    3. Canon PowerShot SD850 IS Camera Lens Replacement: 15 단계, 이미지 1개 중 1개
      • Use a spudger or a flathead screwdriver to remove the camera lens cable located in the front of the camera.
      댓글 쓰기
    4. Canon PowerShot SD850 IS Camera Lens Replacement: 16 단계, 이미지 2개 중 1개 Canon PowerShot SD850 IS Camera Lens Replacement: 16 단계, 이미지 2개 중 2개
      • Use a spudger or a flathead screwdriver and carefully pry out the first flash cable from the bottom of the cable. The white 2 prong power cable pops UP (use spudger below red/black insertion and put upward pressure). For the yellow one, apply pressure horizontally.
      • Next use a spudger or a flathead screwdriver and carefully pry out the second flash cable.
      댓글 쓰기
    5. Canon PowerShot SD850 IS Camera Lens Replacement: 17 단계, 이미지 1개 중 1개
      • Gently remove the flash component from the rest of the camera.
      • Use a spudger or a flathead screwdriver and carefully pry off the plastic piece on top of the flash unit.
      • The flash unit can now be removed and replaced.
      • Be careful not to touch the capacitor attached to the flash unit as it may still be holding a charge!
      댓글 쓰기
    1. Canon PowerShot SD850 IS Camera Lens Replacement, Camera Lens: 18 단계, 이미지 1개 중 1개
      • Remove four screws located on the back of the camera:
      • 6.15 mm #00 Phillips
      • 2.75 mm #00 Phillips
      • 2.15 mm #00 Phillips
      • 2.7 mm #00 Phillips
      댓글 쓰기
    2. Canon PowerShot SD850 IS Camera Lens Replacement: 19 단계, 이미지 1개 중 1개
      • Use a spudger or a flathead screwdriver and carefully pry out the bulb located in the front of the camera on top of the camera lens.
      댓글 쓰기
    3. Canon PowerShot SD850 IS Camera Lens Replacement: 20 단계, 이미지 1개 중 1개
      • Gently remove the camera lens from the rest of the camera.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Peter Tran
회원 가입일: 10/06/10
252 평판
안내서 6개를 작성함
Cal Poly, Team 20-7, Maness Fall 2010 Cal Poly, Team 20-7, Maness Fall 2010 회원
CPSU-MANESS-F10S20G7
6 회원들
안내서 14개를 작성함
2가이드 댓글
If you have a problem on your camera then it is better if you go nearest technician to fix your camera.
Get a good action camera at http://actionshotcam.com
Jerome Tenedero - 답글 공유
step 10 was very unclear, the dark brown part of the cable connector is what is supposed to be lifted. i tried to lift the black part, as the guide stated, and broke off the data cable connector rendering my camera nearly useless
Felix - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 70
전체 시간: 15,335
