주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot SX150 IS Digital Image Sensor Replacement
필요한 것
    1. Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Battery Removal: 1 단계, 이미지 3개 중 1개 Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Battery Removal: 1 단계, 이미지 3개 중 2개 Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Battery Removal: 1 단계, 이미지 3개 중 3개
      • Locate the battery cover on the bottom of the camera.
      • Slide the battery compartment cover the direction the arrow is pointing to open the compartment.
      • Remove batteries.
      댓글 쓰기
    1. Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Prerequisite: 2 단계, 이미지 1개 중 1개
      • Remove the two 2mm screws above the screen using the size J000 screwdriver.
      댓글 쓰기
    2. Canon PowerShot SX150 IS Digital Image Sensor Replacement: 3 단계, 이미지 2개 중 1개 Canon PowerShot SX150 IS Digital Image Sensor Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the two 5mm screws from the side of the camera with the J000 head screw driver.
      • Using the same screwdriver, remove the one 5mm screw from the other side of the camera located under the A/V Out flap.
      댓글 쓰기
    3. Canon PowerShot SX150 IS Digital Image Sensor Replacement: 4 단계, 이미지 1개 중 1개
      • Remove two 4mm screws from the bottom of the camera with the J000 head screw driver.
      댓글 쓰기
    4. Canon PowerShot SX150 IS Digital Image Sensor Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the plastic panel surrounding the back screen.
      댓글 쓰기
    5. Canon PowerShot SX150 IS Digital Image Sensor Replacement: 6 단계, 이미지 3개 중 1개 Canon PowerShot SX150 IS Digital Image Sensor Replacement: 6 단계, 이미지 3개 중 2개 Canon PowerShot SX150 IS Digital Image Sensor Replacement: 6 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Remove the three 3mm screws using the size J000 screw driver from the button plate.
      • Gently flip up the flex ribbon lock and remove the flex ribbon using tweezers.
      • Move the button plate out of the way.
      댓글 쓰기
    6. Canon PowerShot SX150 IS Digital Image Sensor Replacement: 7 단계, 이미지 2개 중 1개 Canon PowerShot SX150 IS Digital Image Sensor Replacement: 7 단계, 이미지 2개 중 2개
      • There is a black flex ribbon lock that must be lifted and unlocked with your tweezers before this flex ribbon will detach.
      • Any small tear could ruin the flex ribbon. Be very gentle while removing it.
      • Gently lift the lock and detach the flex ribbon from the circuit board with the tweezers.
      댓글 쓰기
    7. Canon PowerShot SX150 IS Digital Image Sensor Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the two 2mm screws from the bottom of the screen with the size J000 screw driver.
      • You can then lift the screen out of place and set it aside.
      댓글 쓰기
    8. Canon PowerShot SX150 IS Digital Image Sensor Replacement: 9 단계, 이미지 3개 중 1개 Canon PowerShot SX150 IS Digital Image Sensor Replacement: 9 단계, 이미지 3개 중 2개 Canon PowerShot SX150 IS Digital Image Sensor Replacement: 9 단계, 이미지 3개 중 3개
      • With the J000 Philips head screwdriver, remove the two 2mm screws from under the flash.
      • Using the same screwdriver, remove the two 5mm screws from the bottom. One is under the battery door.
      • With the same screwdriver, remove the 2mm screw at the top of the metal plate.
      댓글 쓰기
    9. Canon PowerShot SX150 IS Digital Image Sensor Replacement: 10 단계, 이미지 2개 중 1개 Canon PowerShot SX150 IS Digital Image Sensor Replacement: 10 단계, 이미지 2개 중 2개
      • Gently detach the flex ribbon with your tweezers before removing the front plate.
      댓글 쓰기
    10. Canon PowerShot SX150 IS Digital Image Sensor Replacement: 11 단계, 이미지 3개 중 1개 Canon PowerShot SX150 IS Digital Image Sensor Replacement: 11 단계, 이미지 3개 중 2개 Canon PowerShot SX150 IS Digital Image Sensor Replacement: 11 단계, 이미지 3개 중 3개
      • Using the J000 Philips head screwdriver, remove the four 7mm screws from the silver panel.
      • Remove the two 5mm screws.
      • Remove the one 3 mm screw.
      • Using the same screwdriver, remove the 3mm screw from the top of the camera.
      • Pull the panel off and set it aside.
      댓글 쓰기
    1. Canon PowerShot SX150 IS Digital Image Sensor Replacement, Digital Image Sensor: 12 단계, 이미지 2개 중 1개 Canon PowerShot SX150 IS Digital Image Sensor Replacement, Digital Image Sensor: 12 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Lift the two flex ribbons with your tweezers and remove them.
      • Move the circuit board to the side.
      댓글 쓰기
    2. Canon PowerShot SX150 IS Digital Image Sensor Replacement: 13 단계, 이미지 2개 중 1개 Canon PowerShot SX150 IS Digital Image Sensor Replacement: 13 단계, 이미지 2개 중 2개
      • Remove the three 2 mm screws from around the sensor.
      • Pull the sensor away.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Avery Hyde
회원 가입일: 09/12/16
146 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 31
전체 시간: 1,468
