주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot SX60 HS Back Panel Replacement
필요한 것
    1. Canon PowerShot SX60 HS Back Panel Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
      • Make sure to power off the device before completing any more steps.
      • Remove the battery by releasing the orange clip in the battery compartment.
      댓글 쓰기
    2. Canon PowerShot SX60 HS Back Panel Replacement: 2 단계, 이미지 2개 중 1개 Canon PowerShot SX60 HS Back Panel Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the rubber eye piece by pulling it back.
      • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the side of the viewfinder.
      댓글 쓰기
    3. Canon PowerShot SX60 HS Back Panel Replacement: 3 단계, 이미지 2개 중 1개 Canon PowerShot SX60 HS Back Panel Replacement: 3 단계, 이미지 2개 중 2개
      • Use the Phillips #00 screwdriver to remove the 4mm #00 screw located on the bottom left of the device.
      • Use the Phillips #00 screwdriver to remove the 5mm #00 screw located on the bottom center of the device.
      • Use the Phillips #00 screwdriver to remove the 7mm #00 screw on the right top corner of the camera, just above the media ports.
      • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the right side, under the media port dust cover.
      댓글 쓰기
    4. Canon PowerShot SX60 HS Back Panel Replacement: 4 단계, 이미지 2개 중 1개 Canon PowerShot SX60 HS Back Panel Replacement: 4 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Ensure the LCD screen is swung fully to the left before taking off the back panel.
      • Use the iFixit opening tool to pry off the back panel.
      • Don't completely pull off the back panel because there is still a ribbon attached.
      • Use the black spudger to unclip the ribbon located behind the battery compartment. Then remove it using the nylon tipped tweezers.
      • Once the ribbon is unplugged, remove the back panel from the camera body.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Ethan Boone
회원 가입일: 07/08/19
812 평판
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 33
전체 시간: 1,179
