주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot SX600 HS Flash Assembly Replacement
필요한 것
  1. Canon PowerShot SX600 HS Flash Assembly Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • To remove the battery, locate the battery cover on the bottom of the camera.
    • Using your thumb, press down on the cover and slide it outwards.
    댓글 쓰기
  2. Canon PowerShot SX600 HS Flash Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Depress the orange lever holding the battery in place to unlock it.
    댓글 쓰기
  3. Canon PowerShot SX600 HS Flash Assembly Replacement: 3 단계, 이미지 2개 중 1개 Canon PowerShot SX600 HS Flash Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Use your fingers to remove the battery.
    • Be sure to remember the alignment of the nodes for reassembly.
    댓글 쓰기
  4. Canon PowerShot SX600 HS Flash Assembly Replacement, Power and Shutter Buttons: 4 단계, 이미지 1개 중 1개
    • Use a #000 Phillips screwdriver to unscrew the four 4mm screws located on the sides of the camera (2 for each side).
    댓글 쓰기
  5. Canon PowerShot SX600 HS Flash Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Unscrew the four 2mm located on the bottom of the camera using a Phillips #000 screwdriver.
    댓글 쓰기
  6. Canon PowerShot SX600 HS Flash Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to loosen and remove both the front and back plates of the camera, as well as the two side pieces.
    댓글 쓰기
  7. Canon PowerShot SX600 HS Flash Assembly Replacement: 7 단계, 이미지 2개 중 1개 Canon PowerShot SX600 HS Flash Assembly Replacement: 7 단계, 이미지 2개 중 2개
    • Unscrew the three 2mm screws attaching the piece to the camera frame with a #000 Phillips screwdriver.
    댓글 쓰기
  8. Canon PowerShot SX600 HS Flash Assembly Replacement: 8 단계, 이미지 1개 중 1개
    • Use an opening tool to gently remove the power and shutter button assembly from the frame.
    댓글 쓰기
  9. Canon PowerShot SX600 HS Flash Assembly Replacement, Display Screen: 9 단계, 이미지 2개 중 1개 Canon PowerShot SX600 HS Flash Assembly Replacement, Display Screen: 9 단계, 이미지 2개 중 2개
    • Unscrew the 2mm screw connections of the main board protector from the camera frame using a #000 Phillips head screwdriver (2 on front, 1 on top)
    댓글 쓰기
  10. Canon PowerShot SX600 HS Flash Assembly Replacement: 10 단계, 이미지 1개 중 1개
    • Use a Phillips #000 screwdriver to unscrew the 4mm screw.
    댓글 쓰기
  11. Canon PowerShot SX600 HS Flash Assembly Replacement: 11 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the no-fuss connector from its holder.
    댓글 쓰기
  12. Canon PowerShot SX600 HS Flash Assembly Replacement: 12 단계, 이미지 1개 중 1개
    • Gently lift the protector from the frame.
    댓글 쓰기
  13. Canon PowerShot SX600 HS Flash Assembly Replacement: 13 단계, 이미지 1개 중 1개
    • Lift the LCD screen ZIF connector tab and remove the ribbon cable.
    • Detach the no-fuss connector.
    • Lift the screen from its holder.
    댓글 쓰기
  14. Canon PowerShot SX600 HS Flash Assembly Replacement, Flash Assembly: 14 단계, 이미지 1개 중 1개
    • Unplug the assembly from the main no-fuss connector.
    댓글 쓰기
  15. Canon PowerShot SX600 HS Flash Assembly Replacement: 15 단계, 이미지 1개 중 1개
    • Unplug the assembly from its flat-top connection.
    댓글 쓰기
  16. Canon PowerShot SX600 HS Flash Assembly Replacement: 16 단계, 이미지 1개 중 1개
    • Use a #000 Phillips screwdriver to remove the three 4mm screws that hold the assembly to the frame.
    댓글 쓰기
  17. Canon PowerShot SX600 HS Flash Assembly Replacement: 17 단계, 이미지 1개 중 1개
    • Gently lift the assembly out of its place.
    댓글 쓰기
결론
Fix your Canon's flash in order to take bright, vibrant photographs.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Scott Childress
회원 가입일: 02/15/17
761 평판
안내서 3개를 작성함
USF Tampa, Team S6-G4, Lacy Spring 2017 USF Tampa, Team S6-G4, Lacy Spring 2017 회원
USFT-LACY-S17S6G4
3 회원들
안내서 9개를 작성함
1가이드 댓글
my SX610 HS flash didn't work. im trying to just troubleshoot it to see if it might came loose or anything. do i still need to do all steps?
Nurul Huda Mohd Asri - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 29
전체 시간: 1,451
