주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon Powershot Pro1 Flash Replacement
필요한 것
  1. Canon Powershot Pro1 Flash Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Locate the battery compartment cover on the right hand side of the camera. The cover features the text: “CF/BATT.OPEN”.
    댓글 쓰기
  2. Canon Powershot Pro1 Flash Replacement: 2 단계, 이미지 1개 중 1개
    • There is an arrow beside the text. Using your hands, slide the cover in the direction of this arrow.
    댓글 쓰기
  3. Canon Powershot Pro1 Flash Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the cover toward you. After doing so you will see the battery sitting inside the compartment.
    댓글 쓰기
  4. Canon Powershot Pro1 Flash Replacement: 4 단계, 이미지 1개 중 1개
    • Press the orange battery lock inside the compartment.
    • Remove the battery.
    • This photo show the battery compartment after the battery has been removed.
    댓글 쓰기
  5. Canon Powershot Pro1 Flash Replacement, Flash: 5 단계, 이미지 2개 중 1개 Canon Powershot Pro1 Flash Replacement, Flash: 5 단계, 이미지 2개 중 2개
    • Remove the 25.4 mm Phillips #0 flash screw. The screw is near the flash.
    • Be careful not to damage the screw.
    댓글 쓰기
  6. Canon Powershot Pro1 Flash Replacement: 6 단계, 이미지 1개 중 1개
    • Locate the small points on both sides of the lens.
    • Pry the lens housing using the black nylon spudger so that it is lifted out of these points.
    • Don't use a screwdriver as a prying tool, this could cause damage.
    댓글 쓰기
  7. Canon Powershot Pro1 Flash Replacement: 7 단계, 이미지 1개 중 1개
    • Use the plastic spudger to remove the upper portion of the flash housing.
    댓글 쓰기
  8. Canon Powershot Pro1 Flash Replacement: 8 단계, 이미지 3개 중 1개 Canon Powershot Pro1 Flash Replacement: 8 단계, 이미지 3개 중 2개 Canon Powershot Pro1 Flash Replacement: 8 단계, 이미지 3개 중 3개
    • Use the nylon spudger to dislodge the flash bulb and capacitor from the housing.
    • Don't use a screwdriver as prying tool, this could cause damage.
    댓글 쓰기
  9. Canon Powershot Pro1 Flash Replacement: 9 단계, 이미지 1개 중 1개
    • Cut the flash and capacitor cables with a wire cutter.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Seana Meegan
회원 가입일: 09/06/19
677 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 23
전체 시간: 1,274
