주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon Powershot Pro1 LCD Screen Replacement
필요한 것
    1. Canon Powershot Pro1 LCD Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Locate the battery compartment cover on the right hand side of the camera. The cover features the text: “CF/BATT.OPEN”.
      댓글 쓰기
    2. Canon Powershot Pro1 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
      • There is an arrow beside the text. Using your hands, slide the cover in the direction of this arrow.
      댓글 쓰기
    3. Canon Powershot Pro1 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
      • Pull the cover toward you. After doing so you will see the battery sitting inside the compartment.
      댓글 쓰기
    4. Canon Powershot Pro1 LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
      • Press the orange battery lock inside the compartment.
      • Remove the battery.
      • This photo show the battery compartment after the battery has been removed.
      댓글 쓰기
    1. Canon Powershot Pro1 LCD Screen Replacement, LCD screen: 5 단계, 이미지 1개 중 1개
      • Open up the LCD screen.
      댓글 쓰기
    2. Canon Powershot Pro1 LCD Screen Replacement: 6 단계, 이미지 2개 중 1개 Canon Powershot Pro1 LCD Screen Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the 1.2 mm Phillips #0 screws on the left and right side of the LCD.
      • Using the Phillips #000 screwdriver, remove the screws on the right (you need to rotate the screen to access the screws on the right, and you will see one on each corner).
      댓글 쓰기
    3. Canon Powershot Pro1 LCD Screen Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the back cover of the LCD screen (has “Canon” written on it).
      댓글 쓰기
    4. Canon Powershot Pro1 LCD Screen Replacement: 8 단계, 이미지 3개 중 1개 Canon Powershot Pro1 LCD Screen Replacement: 8 단계, 이미지 3개 중 2개 Canon Powershot Pro1 LCD Screen Replacement: 8 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Now you will see an exposed circuit board and the backside of the LCD.
      • Fold back the plastic covering and remove the highlighted ribbon cables with tweezers.
      댓글 쓰기
    5. Canon Powershot Pro1 LCD Screen Replacement: 9 단계, 이미지 1개 중 1개
      • Using the nylon spudger, pry the LCD off the screen cover.
      • You can now separate the LCD from the camera.
      • Don't use a metal spudger as this could cause damage to the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Seana Meegan
회원 가입일: 09/06/19
677 평판
안내서 5개를 작성함
1가이드 댓글
Hi, where do I get a replacement lcd screen for this is camera?
Dog EatDog - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 14
지난 30일: 44
전체 시간: 1,462
