주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon Powershot SD880 Flash Replacement
필요한 것
    1. Canon Powershot SD880 Flash Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Canon Powershot SD880 Flash Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Canon Powershot SD880 Flash Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
      • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
      • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
      • One screw will be located under the rubber USB flap.
      • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
      • Slowly pull the back cover off of the camera.
      댓글 쓰기
    1. Canon Powershot SD880 Flash Replacement, Front Cover: 2 단계, 이미지 3개 중 1개 Canon Powershot SD880 Flash Replacement, Front Cover: 2 단계, 이미지 3개 중 2개 Canon Powershot SD880 Flash Replacement, Front Cover: 2 단계, 이미지 3개 중 3개
      • Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
      • Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
      • The two screws on the other side of the camera were already removed when the back cover was taken off.
      댓글 쓰기
    1. Canon Powershot SD880 Flash Replacement, Top Panel: 3 단계, 이미지 2개 중 1개 Canon Powershot SD880 Flash Replacement, Top Panel: 3 단계, 이미지 2개 중 2개
      • Unplug the green and white plugs that connect the top panel to the top of the logic board.
      • Dislodge the tab above the lens.
      • Dislodge the tab at the back.
      댓글 쓰기
    1. Canon Powershot SD880 Flash Replacement, LCD Display: 4 단계, 이미지 3개 중 1개 Canon Powershot SD880 Flash Replacement, LCD Display: 4 단계, 이미지 3개 중 2개 Canon Powershot SD880 Flash Replacement, LCD Display: 4 단계, 이미지 3개 중 3개
      • Remove the two 2.9 mm screws at the top-right corner and bottom-left corner of the LCD screen using a Phillips #0 screwdriver.
      • Disconnect the ribbons that connect the screen to the camera.
      • Lift the screen off.
      댓글 쓰기
    1. Canon Powershot SD880 Flash Replacement, Flash: 5 단계, 이미지 3개 중 1개 Canon Powershot SD880 Flash Replacement, Flash: 5 단계, 이미지 3개 중 2개 Canon Powershot SD880 Flash Replacement, Flash: 5 단계, 이미지 3개 중 3개
      • Use caution when removing the flash, as the capacitor may still have a charge.
      • Remove two 1.8 mm screws from the back using a Phillips #0 screwdriver to disconnect the metal guard.
      • To unplug the ribbon at the top of the camera, gently pull it from the plug-in point.
      • Disconnect the white plug from the red and black wires.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
9다른 기여자 명과 함께
Robert Manno
회원 가입일: 01/05/11
444 평판
안내서 4개를 작성함
Cal Poly, Team 13-3, Forte Winter 2011 Cal Poly, Team 13-3, Forte Winter 2011 회원
CPSU-FORTE-W11S13G3
5 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 39
전체 시간: 3,046
