주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon Selphy CP720 Paper Cassette Replacement
    1. Canon Selphy CP720 Paper Cassette Replacement, Paper Cassette: 1 단계, 이미지 1개 중 1개
      • This configuration allows printing but not reloading of the paper cassette. The cassette needs to be removed before paper can be put inside.
      댓글 쓰기
    2. Canon Selphy CP720 Paper Cassette Replacement: 2 단계, 이미지 1개 중 1개
      • Set the printer on its back so that the Paper Cassette sticks straight up in the air.
      • Pull the Paper Cassette out of the printer. It is guided by two studs that fit into the grooves on the underside of the cassette.
      댓글 쓰기
    3. Canon Selphy CP720 Paper Cassette Replacement: 3 단계, 이미지 1개 중 1개
      • Slide the translucent top cover of the Paper Cassette back to expose the paper storage area.
      • With the top half pulled back, lift the glossy side and open the Cassette.
      댓글 쓰기
    4. Canon Selphy CP720 Paper Cassette Replacement: 4 단계, 이미지 1개 중 1개
      • Put no more than 12 pages in the cassette
      댓글 쓰기
    5. Canon Selphy CP720 Paper Cassette Replacement: 5 단계, 이미지 1개 중 1개
      • Slide the upper clear plastic part back by gripping it on either side and pulling it backward.
      댓글 쓰기
    6. Canon Selphy CP720 Paper Cassette Replacement: 6 단계, 이미지 1개 중 1개
      • Make sure the metal tab on the printer will fit over base of the cassette to allow the hinged ramp to direct the paper into the rollers.
      댓글 쓰기
    7. Canon Selphy CP720 Paper Cassette Replacement: 7 단계, 이미지 1개 중 1개
      • Push the cassette into the printer, with the glossy side up. Make sure that the Cassette is being guided by the studs in the mouth of the printer.
      댓글 쓰기
결론
There, your Selphy CP720 has been loaded with paper.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Peter Ely
회원 가입일: 09/26/18
884 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 21
지난 30일: 74
전체 시간: 4,148
