주요 콘텐츠로 건너뛰기
Canon Vixia HF R62 Speaker Replacement
필요한 것
  1. Canon Vixia HF R62 Speaker Replacement, Outer Shell: 1 단계, 이미지 1/2 Canon Vixia HF R62 Speaker Replacement, Outer Shell: 1 단계, 이미지 2/2
    • Remove the strap by undoing the Velcro and pulling it through the thread points.
    • Remove the external battery pack by pressing down on the slide release and sliding it out.
  2. Canon Vixia HF R62 Speaker Replacement: 2 단계, 이미지 1/2 Canon Vixia HF R62 Speaker Replacement: 2 단계, 이미지 2/2
    • Remove the three 5mm Phillips #000 screws on the bottom of the device.
  3. Canon Vixia HF R62 Speaker Replacement: 3 단계, 이미지 1/2 Canon Vixia HF R62 Speaker Replacement: 3 단계, 이미지 2/2
    • On the side of the device, remove the following Phillips #000 screws:
    • One 3mm screw
    • One 5mm screw
  4. Canon Vixia HF R62 Speaker Replacement: 4 단계, 이미지 1/2 Canon Vixia HF R62 Speaker Replacement: 4 단계, 이미지 2/2
    • Remove the panel opposite the display by pulling up perpendicular to the side.
  5. Canon Vixia HF R62 Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the 4mm Phillips #000 screw that was exposed after taking off the side panel.
  6. Canon Vixia HF R62 Speaker Replacement: 6 단계, 이미지 1/2 Canon Vixia HF R62 Speaker Replacement: 6 단계, 이미지 2/2
    • Remove the three 4mm Phillips #000 screws shown.
    • There will be foam covers protecting some or all of these screws. These will need to be removed before you will be able to unscrew them.
  7. Canon Vixia HF R62 Speaker Replacement: 7 단계, 이미지 1/3 Canon Vixia HF R62 Speaker Replacement: 7 단계, 이미지 2/3 Canon Vixia HF R62 Speaker Replacement: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using tweezers, disconnect this ribbon cable by pulling straight out.
  8. Canon Vixia HF R62 Speaker Replacement: 8 단계, 이미지 1/3 Canon Vixia HF R62 Speaker Replacement: 8 단계, 이미지 2/3 Canon Vixia HF R62 Speaker Replacement: 8 단계, 이미지 3/3
    • Repeat step seven (7) for the remaining three wires shown.
  9. Canon Vixia HF R62 Speaker Replacement: 9 단계, 이미지 1/3 Canon Vixia HF R62 Speaker Replacement: 9 단계, 이미지 2/3 Canon Vixia HF R62 Speaker Replacement: 9 단계, 이미지 3/3
    • Grasp the top of the camera and pull straight up to remove the top panel.
  10. Canon Vixia HF R62 Speaker Replacement, Speaker: 10 단계, 이미지 1/1
    • Grab the top panel and flip it upside down.
  11. Canon Vixia HF R62 Speaker Replacement: 11 단계, 이미지 1/2 Canon Vixia HF R62 Speaker Replacement: 11 단계, 이미지 2/2
    • Remove the 4mm Phillips #000 screw from the front side top panel.
  12. Canon Vixia HF R62 Speaker Replacement: 12 단계, 이미지 1/3 Canon Vixia HF R62 Speaker Replacement: 12 단계, 이미지 2/3 Canon Vixia HF R62 Speaker Replacement: 12 단계, 이미지 3/3
    • Remove the other two 4mm Phillips #000 screws from the green chip.
  13. Canon Vixia HF R62 Speaker Replacement: 13 단계, 이미지 1/1
    • Separate the chip from the black plastic part and remove the black plastic part.
  14. Canon Vixia HF R62 Speaker Replacement: 14 단계, 이미지 1/2 Canon Vixia HF R62 Speaker Replacement: 14 단계, 이미지 2/2
    • Remove four 4mm Phillips #000 screws on the top of the metal part.
  15. Canon Vixia HF R62 Speaker Replacement: 15 단계, 이미지 1/2 Canon Vixia HF R62 Speaker Replacement: 15 단계, 이미지 2/2
    • Take off the electronic component.
  16. Canon Vixia HF R62 Speaker Replacement: 16 단계, 이미지 1/2 Canon Vixia HF R62 Speaker Replacement: 16 단계, 이미지 2/2
결론
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 156
