주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Capresso Perfectea 260 Handle Replacement
필요한 것
    1. Capresso Perfectea 260 Handle Replacement, Lid: 1 단계, 이미지 1개 중 1개
      • Lift the lid of the Perfectea
      • Remove the two 12mm Phillips #2 screws located at the brim of the pot.
      댓글 쓰기
    2. Capresso Perfectea 260 Handle Replacement: 2 단계, 이미지 3개 중 1개 Capresso Perfectea 260 Handle Replacement: 2 단계, 이미지 3개 중 2개 Capresso Perfectea 260 Handle Replacement: 2 단계, 이미지 3개 중 3개
      • Adhesive tape is left holding the lid to the glass pot.
      • Use the spudger for this step.
      • With one hand, firmly grip the lid while designating your other hand to wedge the spudger between the lid and the glass pot.
      • Working from the outside to the inside, gently pry the adhesive tape from the glass pot, detaching the lid.
      댓글 쓰기
    1. Capresso Perfectea 260 Handle Replacement, Handle: 3 단계, 이미지 3개 중 1개 Capresso Perfectea 260 Handle Replacement, Handle: 3 단계, 이미지 3개 중 2개 Capresso Perfectea 260 Handle Replacement, Handle: 3 단계, 이미지 3개 중 3개
      • Use the plastic opening tool for this step.
      • Firmly grip the glass pot with one hand while using the other to slip the flat end of the plastic opening tool between the glass pot and the adhesive tape holding the handle to the glass pot.
      • Gently pry the adhesive tape from the glass pot. Work your way around the handle until the handle is loose and not attached to the pot anymore.
      댓글 쓰기
    2. Capresso Perfectea 260 Handle Replacement: 4 단계, 이미지 1개 중 1개
      • Once the handle is loose, locate the four 10 mm Phillips #2 screws from the base of the Perfectea and remove them.
      • Remove the base.
      댓글 쓰기
    3. Capresso Perfectea 260 Handle Replacement: 5 단계, 이미지 1개 중 1개
      • Locate the two 10 mm Phillips #2 screws at the bottom of the handle and remove them.
      댓글 쓰기
    4. Capresso Perfectea 260 Handle Replacement: 6 단계, 이미지 2개 중 1개 Capresso Perfectea 260 Handle Replacement: 6 단계, 이미지 2개 중 2개
      • In order to free the bottom of the handle, remove the plastic piece that was held by the two screws
      • While firmly holding the glass pot, gently slide the bottom of the handle up and out of the base of the pot.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kenji Anzai
회원 가입일: 04/14/15
594 평판
안내서 4개를 작성함
Cal Poly, Team 6-17, Maness Spring 2015 Cal Poly, Team 6-17, Maness Spring 2015 회원
CPSU-MANESS-S15S6G17
4 회원들
안내서 12개를 작성함
1가이드 댓글
This guide applies to the Capresso H2O kettle too. Thanks for the guide.
Giovanni Ciriani - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 32
전체 시간: 993
