주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Casing and Trigger
필요한 것
  1. Casing and Trigger, Fellowes T7CM Casing and Trigger Replacement: 1 단계, 이미지 1개 중 1개
    • Check to make sure the shredder is not plugged in to any electrical outlet.
    • Remove the shredder from the catch basket and place the silver side down on a flat surface.
    • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
  2. Casing and Trigger: 2 단계, 이미지 1개 중 1개
    • Flip the shredder silver side down and place on a flat even surface.
    • Remove the manufacturer's label in order to gain access to the hidden screw hole.
    • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
  3. Casing and Trigger: 3 단계, 이미지 1개 중 1개
    • Once all of the screws are removed, slowly pull apart the casing.
    • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
    • Use Caution during this procedure to prevent from damaging any of the internal parts.
  4. Casing and Trigger: 4 단계, 이미지 1개 중 1개
    • Open the casing as shown to prevent tangling or damaging the wires.
    • Take note to how the trigger assembly is attached before removal.
    • The trigger assembly is one part and should come off all together with little to no force applied.
    • Remove the trigger assembly.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
John Wisthoff
회원 가입일: 10/12/16
487 평판
안내서 3개를 작성함
IUPUI, Team 2-2, Baechle Fall 2016 IUPUI, Team 2-2, Baechle Fall 2016 회원
IUPUI-BAECHLE-F16S2G2
4 회원들
안내서 16개를 작성함
2가이드 댓글
-Group 1 Recommendations-
Use Caution - Should use the 'Caution' bullet. (Click on the bullet to change bullets)
Take note - Should use the 'Note' bullet.
Second to last bullet on the last step - Should be a note because it is not stating a step, it is a note or reminder for the user.
Deanna Jack - 답글 공유
Where can i buy replacement gears for this shredder?
indymoon - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 19
지난 30일: 58
전체 시간: 4,615
