주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Casio CTK-3200 LCD Screen Replacement
필요한 것
    1. Casio CTK-3200 LCD Screen Replacement, Center Front Panel: 1 단계, 이미지 2개 중 1개 Casio CTK-3200 LCD Screen Replacement, Center Front Panel: 1 단계, 이미지 2개 중 2개
      • Remove the seven 10 mm Phillips #1 screws on the underside of the keyboard that secure the center front panel.
      댓글 쓰기
    2. Casio CTK-3200 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Flip the keyboard over and remove the central panel on the front and place it above the keyboard.
      • Make sure not to sever or strain any connections between the yellow-colored main board and the central panel.
      • If the panel is not easily removable, make sure all the screws are removed from the back.
      댓글 쓰기
    1. Casio CTK-3200 LCD Screen Replacement, Main Board: 3 단계, 이미지 1개 중 1개
      • Make sure you are not putting too much strain on the wires that connect the yellow board to the rest of the piano.
      댓글 쓰기
    2. Casio CTK-3200 LCD Screen Replacement: 4 단계, 이미지 2개 중 1개 Casio CTK-3200 LCD Screen Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the three 12 mm Phillips #2 screws from the green PCB.
      • This step will require you to move some of the motherboard's wiring. Make sure not to separate any of the connection points.
      댓글 쓰기
    3. Casio CTK-3200 LCD Screen Replacement: 5 단계, 이미지 2개 중 1개 Casio CTK-3200 LCD Screen Replacement: 5 단계, 이미지 2개 중 2개
      • Remove all twenty-three of the 10 mm Phillips #1 screws from the yellow circuit board.
      댓글 쓰기
    4. Casio CTK-3200 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
      • The board is now able to be removed from the center front panel. Carefully remove the board, making certain not to break the board or any of the components attached to it.
      • Make sure the center front panel is facing down for this step, as the keys will come loose from the front of the panel.
      댓글 쓰기
    1. Casio CTK-3200 LCD Screen Replacement, LCD Screen: 7 단계, 이미지 2개 중 1개 Casio CTK-3200 LCD Screen Replacement, LCD Screen: 7 단계, 이미지 2개 중 2개
      • Carefully lift out the LCD screen.
      • If the screen has not been taken off before it might seem like it is glued to the board; this is normal.
      댓글 쓰기
    2. Casio CTK-3200 LCD Screen Replacement: 8 단계, 이미지 2개 중 1개 Casio CTK-3200 LCD Screen Replacement: 8 단계, 이미지 2개 중 2개
      • Place your new screen face down into the center panel. Lay the screen exactly as shown in the first image, then let it fall over and land face down into place.
      • Make sure the screen is right side up. This will ensure that all of the electrical components line up correctly when the main board is re-attached to the center panel.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Will Wright
회원 가입일: 10/23/24
369 평판
안내서 2개를 작성함
Cuesta, Team 10-4, Krynen Fall 2024 Cuesta, Team 10-4, Krynen Fall 2024 회원
CUESTA-KRYNEN-F24S10G4
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 25
전체 시간: 558
