주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Casio CZ-1000 Display Screen Replacement
필요한 것
    1. Casio CZ-1000 Display Screen Replacement, Backplate: 1 단계, 이미지 2개 중 1개 Casio CZ-1000 Display Screen Replacement, Backplate: 1 단계, 이미지 2개 중 2개
      • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
      댓글 쓰기
    2. Casio CZ-1000 Display Screen Replacement: 2 단계, 이미지 3개 중 1개 Casio CZ-1000 Display Screen Replacement: 2 단계, 이미지 3개 중 2개 Casio CZ-1000 Display Screen Replacement: 2 단계, 이미지 3개 중 3개
      • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
      • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
      댓글 쓰기
    3. Casio CZ-1000 Display Screen Replacement: 3 단계, 이미지 3개 중 1개 Casio CZ-1000 Display Screen Replacement: 3 단계, 이미지 3개 중 2개 Casio CZ-1000 Display Screen Replacement: 3 단계, 이미지 3개 중 3개
      • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
      • Be sure to avoid cutting any nearby wires or components.
      • Gently slide all the plugs out of their sockets.
      • This will prevent them from catching on anything or damaging the connectors as you lift.
      댓글 쓰기
    1. Casio CZ-1000 Display Screen Replacement, Display Screen: 4 단계, 이미지 2개 중 1개 Casio CZ-1000 Display Screen Replacement, Display Screen: 4 단계, 이미지 2개 중 2개
      • Pull out the orange 24 pin connector.
      • Pull on the orange plastic piece and not the wires. Pulling on the wires can potentially damage the device.
      댓글 쓰기
    2. Casio CZ-1000 Display Screen Replacement: 5 단계, 이미지 2개 중 1개 Casio CZ-1000 Display Screen Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the four 7.5 mm screws that are holding down the metal sheets using a Phillips #1 screwdriver.
      • Set the sheet to the side for now.
      댓글 쓰기
    3. Casio CZ-1000 Display Screen Replacement: 6 단계, 이미지 3개 중 1개 Casio CZ-1000 Display Screen Replacement: 6 단계, 이미지 3개 중 2개 Casio CZ-1000 Display Screen Replacement: 6 단계, 이미지 3개 중 3개
      • Remove the four 5.5 mm screws from the corners of the display screen using a Phillips #1 screwdriver.
      • Lift the side of the display screen that is closer to you and then pull out the screen.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Ayman Benbrahim
회원 가입일: 10/24/24
97 평판
안내서 1개를 작성함
Cuesta, Team 60-3, Krynen Fall 2024 Cuesta, Team 60-3, Krynen Fall 2024 회원
CUESTA-KRYNEN-F24S60G3
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 17
전체 시간: 293
