주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Casio Exilim EX-Z850 Battery Casing Disassembly
필요한 것
  1. Casio Exilim EX-Z850 Battery Casing Disassembly, Casio Exilim EX-Z850 Battery Casing Disassembly: 1 단계, 이미지 1개 중 1개
    • Remove battery before you begin disassembly.
    • Use a Phillips #00 Screwdriver to remove all four of the screws on the right side of the camera with the lens facing you.
    댓글 쓰기
  2. Casio Exilim EX-Z850 Battery Casing Disassembly: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver, unscrew all four screws on the left side of the camera.
    댓글 쓰기
  3. Casio Exilim EX-Z850 Battery Casing Disassembly: 3 단계, 이미지 1개 중 1개
    • Use the Phillips #00 screwdriver to remove all four of the screws on the bottom of the camera.
    • Bottom screws are longer than the top screws, so label accordingly for easy reassembly.
    댓글 쓰기
  4. Casio Exilim EX-Z850 Battery Casing Disassembly: 4 단계, 이미지 3개 중 1개 Casio Exilim EX-Z850 Battery Casing Disassembly: 4 단계, 이미지 3개 중 2개 Casio Exilim EX-Z850 Battery Casing Disassembly: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Once all screws have been removed, slowly pry open the back casing of the camera.
    • Gently remove the ribbon cable from the LCD with tweezers.
    • Set aside back casing of the camera.
    댓글 쓰기
  5. Casio Exilim EX-Z850 Battery Casing Disassembly: 5 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 Battery Casing Disassembly: 5 단계, 이미지 2개 중 2개
    • Use your tweezers to hold the camera secure, while you pull the front cover off of the camera.
    댓글 쓰기
  6. Casio Exilim EX-Z850 Battery Casing Disassembly: 6 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 Battery Casing Disassembly: 6 단계, 이미지 2개 중 2개
    • The bottom of the LCD screen is secured to the frame by small pieces of black tape. You will need to peel the tape away to release the LCD screen.
    • Use your tweezers to lift the LCD screen from the frame.
    댓글 쓰기
  7. Casio Exilim EX-Z850 Battery Casing Disassembly: 7 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 Battery Casing Disassembly: 7 단계, 이미지 2개 중 2개
    • Lift screen away from the camera with your tweezers.
    • Flip screen over gently with your fingers once it is lifted far away enough from the camera.
    댓글 쓰기
  8. Casio Exilim EX-Z850 Battery Casing Disassembly: 8 단계, 이미지 1개 중 1개
    • Use your tweezers to lift the LCD frame from the camera.
    댓글 쓰기
  9. Casio Exilim EX-Z850 Battery Casing Disassembly: 9 단계, 이미지 3개 중 1개 Casio Exilim EX-Z850 Battery Casing Disassembly: 9 단계, 이미지 3개 중 2개 Casio Exilim EX-Z850 Battery Casing Disassembly: 9 단계, 이미지 3개 중 3개
    • Use your tweezers to lift the bar holding the ribbon off.
    • Disconnect the ribbon to release the LCD screen.
    • Use your fingers to pull the LCD screen with the attached ribbon from the camera.
    댓글 쓰기
  10. Casio Exilim EX-Z850 Battery Casing Disassembly: 10 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 Battery Casing Disassembly: 10 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the two screws from the side of the camera that has the strap mount.
    • Remove strap mount by slowly pulling the side of the case so it will dislocate from the top of the camera.
    댓글 쓰기
  11. Casio Exilim EX-Z850 Battery Casing Disassembly: 11 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 Battery Casing Disassembly: 11 단계, 이미지 2개 중 2개
    • Hold the camera facing toward you. Pull up the bar that is securing the ribbon located to the left of the flash.
    • Disconnect the ribbon by prying it off with your fingers.
    댓글 쓰기
  12. Casio Exilim EX-Z850 Battery Casing Disassembly: 12 단계, 이미지 3개 중 1개 Casio Exilim EX-Z850 Battery Casing Disassembly: 12 단계, 이미지 3개 중 2개 Casio Exilim EX-Z850 Battery Casing Disassembly: 12 단계, 이미지 3개 중 3개
    • With the lens facing towards you, pull the L-shaped frame away from the camera.
    • Do not disconnect any of the wires from the camera when pulling the frame.
    • Remove the frame from the two studs and metal tabs keeping it in place at the bottom of the camera.
    댓글 쓰기
  13. Casio Exilim EX-Z850 Battery Casing Disassembly: 13 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 Battery Casing Disassembly: 13 단계, 이미지 2개 중 2개
    • Locate the logic board to the left of the lens. You will see a bar securing a ribbon. Flip the bar up to release the ribbon.
    • Disconnect the ribbon.
    댓글 쓰기
  14. Casio Exilim EX-Z850 Battery Casing Disassembly: 14 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 Battery Casing Disassembly: 14 단계, 이미지 2개 중 2개
    • Use your Phillips #00 screwdriver to remove the two screws connecting the frame to the back of the camera.
    • Lift the frame away on the LCD screen side of the camera.
    댓글 쓰기
  15. Casio Exilim EX-Z850 Battery Casing Disassembly: 15 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 Battery Casing Disassembly: 15 단계, 이미지 2개 중 2개
    • This is what your camera should look like now that you have the battery casing isolated.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
13다른 기여자 명과 함께
Logan
회원 가입일: 01/10/11
313 평판
안내서 2개를 작성함
Cal Poly, Team 4-38, Regan Winter 2011 Cal Poly, Team 4-38, Regan Winter 2011 회원
CPSU-REGAN-W11S4G38
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 57
전체 시간: 4,453
