주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Casio LK-170 Key Replacement
필요한 것
  1. Casio LK-170 Key Replacement, Key: 1 단계, 이미지 3개 중 1개 Casio LK-170 Key Replacement, Key: 1 단계, 이미지 3개 중 2개 Casio LK-170 Key Replacement, Key: 1 단계, 이미지 3개 중 3개
    • You will be removing 17 11mm screws with a JIS-1 screwdriver to detach the back of the keyboard from the front.
    • You will begin by removing 4 screws on each side of the piano, circled in red.
    • You will then remove the four screws that are a little hidden, circled in orange.
    • Next, remove the two screws in the middle of piano, as well as the three screws on the top of the piano, circled in yellow.
    댓글 쓰기
  2. Casio LK-170 Key Replacement: 2 단계, 이미지 2개 중 1개 Casio LK-170 Key Replacement: 2 단계, 이미지 2개 중 2개
    • After flipping the keyboard over to the front, carefully remove the the front panel from the back panel of the keyboard using your hands.
    • You should now see the screws holding the keys in place.
    • There are five 18mm screws per section of keys.
    • With a JIS-1 bit, unscrew the five screws in the section with the key you want to replace.
    댓글 쓰기
  3. Casio LK-170 Key Replacement: 3 단계, 이미지 2개 중 1개 Casio LK-170 Key Replacement: 3 단계, 이미지 2개 중 2개
    • You will be able to pick up the white keys with your hands and remove them.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Samantha Baker
회원 가입일: 01/24/17
443 평판
안내서 4개를 작성함
Cal Poly, Team 13-2, Banghart Winter 2017 Cal Poly, Team 13-2, Banghart Winter 2017 회원
CPSU-BANGHART-W17S13G2
3 회원들
안내서 5개를 작성함
2가이드 댓글
This guide also works for the Casio LK-175.
The keys are in small groups and you will need to purchase the correct ones. Unfortunately, the ones I received from a seller did not match. I think he thought the part was compatible between my keyboard and the one he pulled them from. I very carefully tried super-gluing the key back onto it's section and so far so good (a few hours). Hopefully, the repair will hold.
Thank you for the guide Samantha.
Steve Ferrel - 답글 공유
Do you know if this exposes the circuit board(s)? I need to open my Casio LK175 to figure out why it's only working with batteries. I need to test the power adapter with a load...but the easiest way to do that would probably be measuring the voltage on the pins inside the board.
Thanks for posting this BTW. I saw so many screws on the bottom. I figured a lot of em were holding the keys. I was afraid to open it up, because I figured I'd mess it up. This is very helpful!
Heather Hodge - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 39
전체 시간: 2,958
