주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Casio fx-82MS Button Replacement
필요한 것
    1. Casio fx-82MS Button Replacement, Button: 1 단계, 이미지 2개 중 1개 Casio fx-82MS Button Replacement, Button: 1 단계, 이미지 2개 중 2개
      • This is the calculator in question.
      • The tools you will need are: a Phillips screwdriver, a spudger and a soldering iron.
      • If you don't have access to a solding iron, you need a stanley knife instead.
      댓글 쓰기
    2. Casio fx-82MS Button Replacement: 2 단계, 이미지 1개 중 1개
      • Flip over the calculator.
      • Locate the 6 screws on the backside.
      • Remove all six screws.
      댓글 쓰기
    3. Casio fx-82MS Button Replacement: 3 단계, 이미지 1개 중 1개
      • Once all six screws have been removed, take the back part off of the calculator.
      댓글 쓰기
    4. Casio fx-82MS Button Replacement: 4 단계, 이미지 2개 중 1개 Casio fx-82MS Button Replacement: 4 단계, 이미지 2개 중 2개
      • Locate the rubber contact points.
      • Solder the rubber contact points, while using the spudger to pry the PCB loose.
      • PCB stands for Printed Circuit Board.
      • Toxic gasses might be created. Hence, do this in a well ventilated room.
      • Start with the lower plugs (left on the photo). Gently pry the PCB loose at the same time.
      • For this step a third person is required for safety. One person uses the solder iron, the other one uses the spudger to pry the PCB loose.
      • If you don't have accessibility to a solder iron, use a utility knife to remove the plugs.
      댓글 쓰기
    5. Casio fx-82MS Button Replacement: 5 단계, 이미지 1개 중 1개
      • After having soldered away all six plugs, lift up the PCB.
      • Flip the board sideways as shown in the picture.
      댓글 쓰기
    6. Casio fx-82MS Button Replacement: 6 단계, 이미지 2개 중 1개 Casio fx-82MS Button Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the rubber mat.
      • Do this carefully, to make sure the buttons stay in their place.
      댓글 쓰기
    7. Casio fx-82MS Button Replacement: 7 단계, 이미지 2개 중 1개 Casio fx-82MS Button Replacement: 7 단계, 이미지 2개 중 2개
      • Replace the broken button.
      댓글 쓰기
    8. Casio fx-82MS Button Replacement: 8 단계, 이미지 2개 중 1개 Casio fx-82MS Button Replacement: 8 단계, 이미지 2개 중 2개
      • Put the rubber mat back in its place.
      • Make sure you push the six slightly damaged plugs through the rubber mat.
      댓글 쓰기
    9. Casio fx-82MS Button Replacement: 9 단계, 이미지 1개 중 1개
      • Push the PCB back into place.
      • Again make sure you push the slightly damaged plugs through the PCB, to make everything fits perfectly again.
      댓글 쓰기
    10. Casio fx-82MS Button Replacement: 10 단계, 이미지 1개 중 1개
      • Place the back side of the casing back on top of the front.
      댓글 쓰기
    11. Casio fx-82MS Button Replacement: 11 단계, 이미지 1개 중 1개
      • Put all six screws back in the back side of the casing.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Rebecca Dowling
회원 가입일: 12/05/16
107 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 22
지난 30일: 96
전체 시간: 4,393
