주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ceiling Fan Light Fixture Replacement
필요한 것
    1. Ceiling Fan Light  Fixture Replacement, Light Fixture: 1 단계, 이미지 3개 중 1개 Ceiling Fan Light  Fixture Replacement, Light Fixture: 1 단계, 이미지 3개 중 2개 Ceiling Fan Light  Fixture Replacement, Light Fixture: 1 단계, 이미지 3개 중 3개
      • Working with electrical wires could lead to electrocution.
      • Find your circuit breaker panel and turn off the breaker that corresponds to your ceiling lights.
      • Do this by pushing it to the right.
      • Also flip your light switch to off.
      댓글 쓰기
    2. Ceiling Fan Light  Fixture Replacement: 2 단계, 이미지 2개 중 1개 Ceiling Fan Light  Fixture Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the two 1.4 mm Phillips head screws that hold the fixture to the fan itself.
      • Once loose, pull down to expose the two connecting wires.
      댓글 쓰기
    3. Ceiling Fan Light  Fixture Replacement: 3 단계, 이미지 3개 중 1개 Ceiling Fan Light  Fixture Replacement: 3 단계, 이미지 3개 중 2개 Ceiling Fan Light  Fixture Replacement: 3 단계, 이미지 3개 중 3개
      • Disconnect these wires by twisting the caps in a counter-clockwise direction.
      • You only need to disconnect the wires coming from the lighting fixture.
      • Once both caps are removed, simply pull the wires apart to remove the fixture.
      댓글 쓰기
    4. Ceiling Fan Light  Fixture Replacement: 4 단계, 이미지 2개 중 1개 Ceiling Fan Light  Fixture Replacement: 4 단계, 이미지 2개 중 2개
      • Loosen the nut holding the ceiling fan piece to the lighting fixture.
      • This step may require a crescent wrench if finger force is not enough.
      댓글 쓰기
    5. Ceiling Fan Light  Fixture Replacement: 5 단계, 이미지 1개 중 1개
      • Pull upwards to remove the fan piece that holds the light fixture.
      • Your model may require you to twist this piece in a counter-clockwise motion to remove.
      댓글 쓰기
    6. Ceiling Fan Light  Fixture Replacement: 6 단계, 이미지 1개 중 1개
      • Switch out the old fixture with your new fixture by doing the last two steps in reverse order.
      댓글 쓰기
    7. Ceiling Fan Light  Fixture Replacement: 7 단계, 이미지 2개 중 1개 Ceiling Fan Light  Fixture Replacement: 7 단계, 이미지 2개 중 2개
      • To connect your new fixture, locate the black wire from your light and the colored wire from the fan.
      • Be sure to attached the colored wires to each other, and white wires to each other. (Positive-Positive, Negative-Negative)
      • Twist these together. Do the same with the two white wires.
      댓글 쓰기
    8. Ceiling Fan Light  Fixture Replacement: 8 단계, 이미지 2개 중 1개 Ceiling Fan Light  Fixture Replacement: 8 단계, 이미지 2개 중 2개
      • Your new light fixture should come with replacement caps. Twist these in a clockwise motion over your wire ends to ensure connection.
      • The old caps work just as well for this if you were not given new ones.
      댓글 쓰기
    9. Ceiling Fan Light  Fixture Replacement: 9 단계, 이미지 1개 중 1개
      • Be sure to neatly tuck in all wires when re-attaching the fixture.
      • Failure to do this will result in not being able to correctly close the gap and put in the screws.
      댓글 쓰기
    10. Ceiling Fan Light  Fixture Replacement: 10 단계, 이미지 1개 중 1개
      • Flip your breaker back on, turn on your light switch, and enjoy your new lights!
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 12명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Garrett Janetzky
회원 가입일: 09/29/15
613 평판
안내서 1개를 작성함
Cal Poly, Team 14-1, Green Fall 2015 Cal Poly, Team 14-1, Green Fall 2015 회원
CPSU-GREEN-F15S14G1
4 회원들
안내서 4개를 작성함
11가이드 댓글
Amazingly instructive, informative and concise. Brilliant.
Jeanie Bolin-Moore - 답글 공유
It's awesome
Nandish Reddy - 답글 공유
Just what I needed. Thanks.
bob.mohler - 답글 공유
Does it have remote control??
ceiling fan manufacturers in india
Abhijeet Khole - 답글 공유
Could someone provide the name of the light fixture used in the demonstration?
THOMAS DUFF - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 37
지난 30일: 132
전체 시간: 37,317
