주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement
필요한 것
    1. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Position Device: 1 단계, 이미지 1개 중 1개
      • Place the meter face down, and the back panel and screws can be seen.
      댓글 쓰기
    2. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Back Panel Screws: 2 단계, 이미지 2개 중 1개 Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Back Panel Screws: 2 단계, 이미지 2개 중 2개
      • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
      댓글 쓰기
    3. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Back Panel: 3 단계, 이미지 1개 중 1개
      • Remove the back panel of the device by lifting upward.
      • Remove the battery from the meter before continuing.
      댓글 쓰기
    4. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Unscrew Motherboard: 4 단계, 이미지 2개 중 1개 Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Unscrew Motherboard: 4 단계, 이미지 2개 중 2개
      • Remove the four 7mm Phillips screws holding the circuit board in place.
      댓글 쓰기
    5. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Motherboard: 5 단계, 이미지 1개 중 1개
      • Gently lift the circuit board away from the device casing.
      • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
      댓글 쓰기
    1. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Locate Dial: 6 단계, 이미지 1개 중 1개
      • The dial is located in the central part of the device.
      댓글 쓰기
    2. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Remove Dial: 7 단계, 이미지 1개 중 1개
      • Carefully remove dial from device by lifting upward.
      • Clean existing dial or replace if necessary.
      • Take care not to lose the small ball bearings.
      댓글 쓰기
    1. Cen-Tech Seven Function Digital Multimeter Ball Bearings Replacement, Locate and Remove Ball Bearings: 8 단계, 이미지 1개 중 1개
      • Locate ball bearings. Carefully remove.
      • If both ball bearings are still present, try lubricating ball bearings with multi-use lubricant.
      • If one or both ball bearings are missing, simply replace.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Anna Kihm
회원 가입일: 10/13/14
965 평판
안내서 5개를 작성함
Clemson, Team 2-4, Benson Fall 2014 Clemson, Team 2-4, Benson Fall 2014 회원
CLEM-BENSON-F14S2G4
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 22
전체 시간: 2,798
