주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Cen-Tech Seven Function Digital Multimeter Battery Replacement
필요한 것
    1. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Position Device: 1 단계, 이미지 1개 중 1개
      • Place the meter face down, and the back panel and screws can be seen.
      댓글 쓰기
    2. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Back Panel Screws: 2 단계, 이미지 2개 중 1개 Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Back Panel Screws: 2 단계, 이미지 2개 중 2개
      • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
      댓글 쓰기
    3. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Back Panel: 3 단계, 이미지 1개 중 1개
      • Remove the back panel of the device by lifting upward.
      • Remove the battery from the meter before continuing.
      댓글 쓰기
    4. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Unscrew Motherboard: 4 단계, 이미지 2개 중 1개 Cen-Tech Seven Function Digital Multimeter Battery Replacement, Unscrew Motherboard: 4 단계, 이미지 2개 중 2개
      • Remove the four 7mm Phillips screws holding the circuit board in place.
      댓글 쓰기
    5. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Motherboard: 5 단계, 이미지 1개 중 1개
      • Gently lift the circuit board away from the device casing.
      • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
      댓글 쓰기
    1. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Locate Battery Attachment: 6 단계, 이미지 1개 중 1개
      • After removing the outer casing and motherboard of the device, locate the attachment site of the battery to the motherboard.
      댓글 쓰기
    2. Cen-Tech Seven Function Digital Multimeter Battery Replacement, Remove Battery: 7 단계, 이미지 1개 중 1개
      • Unsnap the battery from its attachment plate.
      • When replacing the battery with a new one, be sure to properly align battery heads (positive and negative) with snaps. The positive battery head should be connected to the negative wire, and vice versa.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Anna Kihm
회원 가입일: 10/13/14
965 평판
안내서 5개를 작성함
Clemson, Team 2-4, Benson Fall 2014 Clemson, Team 2-4, Benson Fall 2014 회원
CLEM-BENSON-F14S2G4
4 회원들
안내서 18개를 작성함
6가이드 댓글
My case was glued or welded together. I thought it was going to break elsewhere first
No need to remove the board. Just use a screwdriver to pop the battery connector off
Osman Vincent - 답글 공유
In at least some of these meters, the caution label has been applied upside-down, so that it covers the screw holes.
dan - 답글 공유
The top of the panel has two tabs engaged (can be seen by carefully examining photos above). After screws are freed, lift the bottom edge first to allow tabs to disengage. Also, routing of battery clip wires is critical; take care that they clear the case edges.
dan - 답글 공유
Can't get 2nd screw out!!
KARIN SPURLING - 답글 공유
I had a spring in mine, and when my grandson took it apart to change battery, I don’t know where the spring came out
Rodney Grainger - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 21
지난 30일: 110
전체 시간: 16,381
