주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Cen-Tech Seven Function Digital Multimeter Screen Replacement
필요한 것
  1. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Position Device: 1 단계, 이미지 1개 중 1개
    • Place the meter face down, and the back panel and screws can be seen.
  2. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel Screws: 2 단계, 이미지 2개 중 1개 Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel Screws: 2 단계, 이미지 2개 중 2개
    • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
  3. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel: 3 단계, 이미지 1개 중 1개
    • Remove the back panel of the device by lifting upward.
    • Remove the battery from the meter before continuing.
  4. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Unscrew Motherboard: 4 단계, 이미지 2개 중 1개 Cen-Tech Seven Function Digital Multimeter Screen Replacement, Unscrew Motherboard: 4 단계, 이미지 2개 중 2개
    • Remove the four 7mm Phillips screws holding the circuit board in place.
  5. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Motherboard: 5 단계, 이미지 1개 중 1개
    • Gently lift the circuit board away from the device casing.
    • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
  6. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Locate Screen: 6 단계, 이미지 1개 중 1개
    • The screen is located at the top of the device.
  7. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Screen: 7 단계, 이미지 1개 중 1개
    • Carefully remove screen from device by lifting upward.
결론
작성자
3다른 기여자 명과 함께
Anna Kihm
회원 가입일: 10/13/14
965 평판
안내서 5개를 작성함
Clemson, Team 2-4, Benson Fall 2014 Clemson, Team 2-4, Benson Fall 2014 회원
CLEM-BENSON-F14S2G4
4 회원들
안내서 6개를 작성함
1가이드 댓글
my multimeter display is broken, where can i buy a new one?
allwynrajkumar - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 39
전체 시간: 2,962
