주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Chef's Choice M115 Power Switch Replacement
필요한 것
  1. Chef's Choice M115 Power Switch Replacement, Case: 1 단계, 이미지 2개 중 1개 Chef's Choice M115 Power Switch Replacement, Case: 1 단계, 이미지 2개 중 2개
    • Remove the two rubber feet on the motor side of the device.
    • Remove the five Phillips screws from the bottom of the case.
    • These screws are recessed deep in the device, so a long, thin screwdriver is required.
    댓글 쓰기
  2. Chef's Choice M115 Power Switch Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two hex-cap screws on the bottom using a pair of pliers.
    댓글 쓰기
  3. Chef's Choice M115 Power Switch Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully flip the device right-side-up while grasping the top and bottom pieces.
    • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
    댓글 쓰기
  4. Chef's Choice M115 Power Switch Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the sharpener guard by gently pulling up on it.
    • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
    댓글 쓰기
  5. Chef's Choice M115 Power Switch Replacement, Power Switch: 5 단계, 이미지 1개 중 1개
    • Carefully lift the entire motor assembly out of the case.
    댓글 쓰기
  6. Chef's Choice M115 Power Switch Replacement: 6 단계, 이미지 2개 중 1개 Chef's Choice M115 Power Switch Replacement: 6 단계, 이미지 2개 중 2개
    • Using a screw driver, unclip the edges of the switch by pushing them inwards and nudging the switch out of the plastic casing. You will hear a click when the edges unhook from the casing.
    댓글 쓰기
  7. Chef's Choice M115 Power Switch Replacement: 7 단계, 이미지 2개 중 1개 Chef's Choice M115 Power Switch Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the spade connectors from the switch by pulling only on the connector, not the wire.
    • This may require a fair bit of force. Use caution to not damage the device, yourself, or your surroundings.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Hatontola malawo
회원 가입일: 09/17/15
147 평판
안내서 1개를 작성함
IUPUI, Team 3-3, Harley Fall 2015 IUPUI, Team 3-3, Harley Fall 2015 회원
IUPUI-HARLEY-F15S3G3
5 회원들
안내서 14개를 작성함
1가이드 댓글
What kind of switch should I replace the bad switch with? Is there one on Amazon ?
Ryan Frawley - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 26
전체 시간: 671
