주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Chef's Choice M115 Sharpening Stones Replacement
필요한 것
    1. Chef's Choice M115 Sharpening Stones Replacement, Case: 1 단계, 이미지 2개 중 1개 Chef's Choice M115 Sharpening Stones Replacement, Case: 1 단계, 이미지 2개 중 2개
      • Remove the two rubber feet on the motor side of the device.
      • Remove the five Phillips screws from the bottom of the case.
      • These screws are recessed deep in the device, so a long, thin screwdriver is required.
      댓글 쓰기
    2. Chef's Choice M115 Sharpening Stones Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the two hex-cap screws on the bottom using a pair of pliers.
      댓글 쓰기
    3. Chef's Choice M115 Sharpening Stones Replacement: 3 단계, 이미지 1개 중 1개
      • Carefully flip the device right-side-up while grasping the top and bottom pieces.
      • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
      댓글 쓰기
    4. Chef's Choice M115 Sharpening Stones Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the sharpener guard by gently pulling up on it.
      • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
      댓글 쓰기
    1. Chef's Choice M115 Sharpening Stones Replacement, Sharpening Stones: 5 단계, 이미지 2개 중 1개 Chef's Choice M115 Sharpening Stones Replacement, Sharpening Stones: 5 단계, 이미지 2개 중 2개
      • With the outer case removed, firmly grasp the motor-axle attachment and remove it from the base. It should come right off of the assembly.
      댓글 쓰기
    2. Chef's Choice M115 Sharpening Stones Replacement: 6 단계, 이미지 2개 중 1개 Chef's Choice M115 Sharpening Stones Replacement: 6 단계, 이미지 2개 중 2개
      • Use a screwdriver to push the linkage pins out of the rod.
      • Use pliers to pull the pins the rest of the way out.
      • Remove all the linkage pins necessary to slide desired sharpening stone off the end of the shaft.
      댓글 쓰기
    3. Chef's Choice M115 Sharpening Stones Replacement: 7 단계, 이미지 3개 중 1개 Chef's Choice M115 Sharpening Stones Replacement: 7 단계, 이미지 3개 중 2개 Chef's Choice M115 Sharpening Stones Replacement: 7 단계, 이미지 3개 중 3개
      • On the rotating apparatus, holding the sharpening stones in place, are two C-clamps that grip the axle.
      • Remove the C-clamps by applying pressure to both sides of the "C" and pushing the clamp over and off of the axle.
      • Pull the bearing off the shaft. It is in between the two C-clamps.
      • These clamps are very small; use caution to avoid dropping them on the ground or losing them.
      댓글 쓰기
    4. Chef's Choice M115 Sharpening Stones Replacement: 8 단계, 이미지 1개 중 1개
      • Pull sharpening stones off the end of the shaft.
      • Be sure to remember the order and placement of each individual stone so you can reassemble them in the same order.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Zachary Nagel
회원 가입일: 09/17/15
116 평판
안내서 1개를 작성함
IUPUI, Team 3-3, Harley Fall 2015 IUPUI, Team 3-3, Harley Fall 2015 회원
IUPUI-HARLEY-F15S3G3
5 회원들
안내서 14개를 작성함
9가이드 댓글
where does one get the replacement stones. im not seeing they in my amazon/google searches. also cant seem to see them on manufacturers website section for parts.
john molloy - 답글 공유
I have the same question.
August Coombs - 답글 공유
same question, where do I order replacement stones ?? I have the chef’s choice Sportsman from cabelas, thanks in advance .. you can send any info to my e-mail thebobster@ns.sympatico.ca any info wiuld be greatly appreciated..
Bobby Aucoin - 답글 공유
Same question. Where to Purchase sharpen stones. Would like to have them before I disassembled the unit. I have had my sharpener for eight years and use it quite often as my wife likes sharp knives.
Please does anybody have any information to purchase the sharpening stones
Rich - 답글 공유
**Same question. Where do I purchase sharpener replacements.
=on research,
Chef's-Choice customer Support indicated 'no serviceable parts inside /or provided', return the sharpener to manufacturer for an evaluation 'repair cost estimate". They do not give estimates on any work or the wheels, they need to have it in hand in their service department for an 'estimate' on repairs.
~therefore appears
no Chef's-choice sharpeners have replacement service parts available or service documentation available to the customer.
Having opened one up and examined the one I have,
^DIY ?
...a fine-Gd quality diamond/emery paper and a Gd-quality adhesive from a hardware is your options unless you want to return it to them.
Though I was thinking a small cutting wheel of same shape size for a refit, saw a collection of sizes when at harbor-f week or so ago but thik to course an app
..Follow Up
(Just for yucks tried contacted chef- on return mine for 'service evaluation', no return to me email_call_text, disposable?, Lol) out of t
steve - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 23
지난 30일: 125
전체 시간: 8,203
