주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Chefmate TO-09 Timer Replacement
필요한 것
    1. Chefmate TO-09 Timer Replacement, Chefmate TO-09 Timer Replacement: 1 단계, 이미지 3개 중 1개 Chefmate TO-09 Timer Replacement, Chefmate TO-09 Timer Replacement: 1 단계, 이미지 3개 중 2개 Chefmate TO-09 Timer Replacement, Chefmate TO-09 Timer Replacement: 1 단계, 이미지 3개 중 3개
      • Examine the condition of the appliance.
      • Remove the tray from inside the toaster oven before dissembling.
      • With the tray removed, this is a great opportunity to clean your toaster oven . Built up debris left over time could lead to functional issues in the future!
      댓글 쓰기
    2. Chefmate TO-09 Timer Replacement: 2 단계, 이미지 3개 중 1개 Chefmate TO-09 Timer Replacement: 2 단계, 이미지 3개 중 2개 Chefmate TO-09 Timer Replacement: 2 단계, 이미지 3개 중 3개
      • Flip the toaster oven on its head so that its bottom side is facing upwards.
      • Use a Phillips #0 screwdriver to remove the four screws hidden underneath the legs of the appliance.
      • There are two legs covering the two screws in the front peg .
      • The other two screws are visible under the back legs.
      댓글 쓰기
    3. Chefmate TO-09 Timer Replacement: 3 단계, 이미지 3개 중 1개 Chefmate TO-09 Timer Replacement: 3 단계, 이미지 3개 중 2개 Chefmate TO-09 Timer Replacement: 3 단계, 이미지 3개 중 3개
      • Return the toaster oven to its upright position and rotate it so its backside is facing you.
      • Use the Phillips #0 screwdriver to unscrew the four screws visible on the backside.
      • Keep track of loose screws for later re-assembly.
      댓글 쓰기
    4. Chefmate TO-09 Timer Replacement: 4 단계, 이미지 3개 중 1개 Chefmate TO-09 Timer Replacement: 4 단계, 이미지 3개 중 2개 Chefmate TO-09 Timer Replacement: 4 단계, 이미지 3개 중 3개
      • With the appliance facing you, remove the top cover of the toaster oven to access the timer location.
      댓글 쓰기
    5. Chefmate TO-09 Timer Replacement: 5 단계, 이미지 3개 중 1개 Chefmate TO-09 Timer Replacement: 5 단계, 이미지 3개 중 2개 Chefmate TO-09 Timer Replacement: 5 단계, 이미지 3개 중 3개
      • Use the flat screwdriver as a wedge and pop the timer knob out of place.
      • If you have difficulty removing the timer by hand, use a flat plier to pry off the timer knob.
      댓글 쓰기
    6. Chefmate TO-09 Timer Replacement: 6 단계, 이미지 3개 중 1개 Chefmate TO-09 Timer Replacement: 6 단계, 이미지 3개 중 2개 Chefmate TO-09 Timer Replacement: 6 단계, 이미지 3개 중 3개
      • With the timer in hand, gently remove the two wires attached to the square object.
      • Unplug the timer wire gently, or else this may cause damage to the cables.
      댓글 쓰기
    7. Chefmate TO-09 Timer Replacement: 7 단계, 이미지 3개 중 1개 Chefmate TO-09 Timer Replacement: 7 단계, 이미지 3개 중 2개 Chefmate TO-09 Timer Replacement: 7 단계, 이미지 3개 중 3개
      • Before replacing your timer with a new one, you may try to lubricate it first to see if it fixes the issue.
      • Apply WD-40 to the timer's slight peek edge.
      • Let the WD-40 sit and take effect for around 30 seconds or a minute after you spray it onto the timer.
      • The WD-40's oil will seep inside the timer, reaching the tiny gear of the timer.
      • WD-40 is flammable. Be sure to read the instruction label before using WD-40 Two-Way Spray Can.
      • Not cleaning/wiping off excess WD-40 oil on the timer will start a fire in the toaster oven.
      • You can test the timer using a flat head screwdriver to turn the timer to see if it ticks/works.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Andy Tran
회원 가입일: 04/05/22
172 평판
안내서 1개를 작성함
CSU Los Angeles, Team 4-61, Briggs Spring 2022 CSU Los Angeles, Team 4-61, Briggs Spring 2022 회원
CSULA-BRIGGS-S22S4G61
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 28
전체 시간: 874
