주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Chrome OS Software Guide
      • Locate the power button to turn on your Chromebook. On most Chromebook computers/laptops, the power button is on the left or right side of the device.
      댓글 쓰기
    1. Chrome OS Software Guide, Language settings: 2 단계, 이미지 1개 중 1개
      • Once the welcome screen appears on the screen, check that the language is the one you prefer, then click Continue (Let's Go)
      댓글 쓰기
    2. Chrome OS Software Guide, Wi-Fi settings: 3 단계, 이미지 1개 중 1개
      • Connect to your Wi-Fi. You will then be prompted to enter your password; you can also check to see if your password is correct (by clicking on the eye icon on the right).
      • Click on Connect after inserting the password.
      댓글 쓰기
    3. Chrome OS Software Guide, Account settings: 4 단계, 이미지 1개 중 1개
      • Create a new Gmail account, or use your existing Gmail address to activate your account.
      • Click Next to continue
      댓글 쓰기
    4. Chrome OS Software Guide, Connection to Google Apps and Services: 5 단계, 이미지 1개 중 1개
      • Here you will see the Google Apps and Services section. Google Apps and Services are the built-in apps like Gmail, Google Docs, and Google Drive.
      • You can enable the "Backup to Google Drive" option. This basically saves your work in the "Cloud" so you can access your documents from your computer, as long as you're connected to Google.
      • Click more and follow the procedures.
      댓글 쓰기
      • If you want to connect your phone, click on "Select a device" and follow the instructions, or you can skip it by clicking on "No thanks".
      댓글 쓰기
    5. Chrome OS Software Guide, The last steps: 7 단계, 이미지 1개 중 1개
      • You can now take a brief tour of how the different features of your Chromebook are used. Or you can click the 'X' to close and move on without taking the tour.
      댓글 쓰기
결론
Thank you for reading this guide!
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
es en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Leah Walker
회원 가입일: 02/16/21
1,604 평판
안내서 5개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
45 회원들
안내서 12,108개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 41
전체 시간: 727
