주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Cirago M9030 IDE Connector Replacement
필요한 것
    1. Cirago M9030 IDE Connector Replacement, Cover: 1 단계, 이미지 1개 중 1개
      • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
      댓글 쓰기
    2. Cirago M9030 IDE Connector Replacement: 2 단계, 이미지 1개 중 1개
      • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
      • Remove the warranty sticker across the bottom.
      댓글 쓰기
    3. Cirago M9030 IDE Connector Replacement: 3 단계, 이미지 2개 중 1개 Cirago M9030 IDE Connector Replacement: 3 단계, 이미지 2개 중 2개
      • Gently take the cover apart using your hands separating the top and bottom.
      • The outer shell is expected to easily come apart.
      댓글 쓰기
    1. Cirago M9030 IDE Connector Replacement, Hard Drive: 4 단계, 이미지 1개 중 1개
      • Make sure that the screen of the device is facing down.
      댓글 쓰기
    2. Cirago M9030 IDE Connector Replacement: 5 단계, 이미지 3개 중 1개 Cirago M9030 IDE Connector Replacement: 5 단계, 이미지 3개 중 2개 Cirago M9030 IDE Connector Replacement: 5 단계, 이미지 3개 중 3개
      • Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
      • Raise the bottom edge of the hard drive 15 degrees up from the device.
      댓글 쓰기
    3. Cirago M9030 IDE Connector Replacement: 6 단계, 이미지 3개 중 1개 Cirago M9030 IDE Connector Replacement: 6 단계, 이미지 3개 중 2개 Cirago M9030 IDE Connector Replacement: 6 단계, 이미지 3개 중 3개
      • Place fingers on the IDE connectors gently picking up and sliding the hard drive out from the IDE module.
      댓글 쓰기
    1. Cirago M9030 IDE Connector Replacement, IDE Connector: 7 단계, 이미지 2개 중 1개 Cirago M9030 IDE Connector Replacement, IDE Connector: 7 단계, 이미지 2개 중 2개
      • Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard located at the top.
      댓글 쓰기
    2. Cirago M9030 IDE Connector Replacement: 8 단계, 이미지 1개 중 1개
      • Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
      댓글 쓰기
    3. Cirago M9030 IDE Connector Replacement: 9 단계, 이미지 2개 중 1개 Cirago M9030 IDE Connector Replacement: 9 단계, 이미지 2개 중 2개
      • Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
      • Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
      댓글 쓰기
    4. Cirago M9030 IDE Connector Replacement: 10 단계, 이미지 1개 중 1개
      • Using the plastic opening tool, completely lift the ribbon off of the motherboard.
      댓글 쓰기
    5. Cirago M9030 IDE Connector Replacement: 11 단계, 이미지 2개 중 1개 Cirago M9030 IDE Connector Replacement: 11 단계, 이미지 2개 중 2개
      • The audio jack is attached to the IDE connector. Pull at a 45 degree angle from the audio jack.
      • Completely remove the IDE connector from the device.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Once you've replaced the IDE connector and reassembled your Cirago M9030, your device should be able to detect hard drives properly again. If everything is connected correctly, your repair is complete. Great job!
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Ryan Sutardji
회원 가입일: 06/29/12
171 평판
안내서 7개를 작성함
Cal Poly, Team 1-4, Regan SU 2012 Cal Poly, Team 1-4, Regan SU 2012 회원
CPSU-REGAN-SU12S1G4
4 회원들
안내서 56개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 33
전체 시간: 1,329
