주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Cisco 878 Integrated Services Router StrataFlash Memory module Disassembly
필요한 것
    1. Cisco 878 Integrated Services Router StrataFlash Memory module Disassembly, Remove the two screws on back side: 1 단계, 이미지 3개 중 1개 Cisco 878 Integrated Services Router StrataFlash Memory module Disassembly, Remove the two screws on back side: 1 단계, 이미지 3개 중 2개 Cisco 878 Integrated Services Router StrataFlash Memory module Disassembly, Remove the two screws on back side: 1 단계, 이미지 3개 중 3개
      • Only trained and qualified personnel should be allowed to install, replace, or service this equipment!
      • During this procedure, wear grounding wrist straps to avoid ESD damage to the card. Do not directly touch the backplane with your hand or any metal tool, or you could shock yourself!
      • Make sure that the power switch is turned to standby and that the power supply cable is disconnected. Disconnect all cables from the router back panel.
      • Use the Phillips #1 Screwdriver to remove the two screws on back side of the device.
      댓글 쓰기
    2. Cisco 878 Integrated Services Router StrataFlash Memory module Disassembly, Remove top cover: 2 단계, 이미지 3개 중 1개 Cisco 878 Integrated Services Router StrataFlash Memory module Disassembly, Remove top cover: 2 단계, 이미지 3개 중 2개 Cisco 878 Integrated Services Router StrataFlash Memory module Disassembly, Remove top cover: 2 단계, 이미지 3개 중 3개
      • 1. Gently push the top cover of the router away from you.
      • 2. Lift it up top cover from the bottom of the router.
      • 3. Remove top cover from the device.
      • Place the router bottom on an antistatic mat.
      댓글 쓰기
    1. Cisco 878 Integrated Services Router StrataFlash Memory module Disassembly, Remove the three screws on front side: 3 단계, 이미지 2개 중 1개 Cisco 878 Integrated Services Router StrataFlash Memory module Disassembly, Remove the three screws on front side: 3 단계, 이미지 2개 중 2개
      • Use the Phillips #1 Screwdriver to remove the three screws on front side of the device.
      댓글 쓰기
    2. Cisco 878 Integrated Services Router StrataFlash Memory module Disassembly, Remove the inner metal shield: 4 단계, 이미지 3개 중 1개 Cisco 878 Integrated Services Router StrataFlash Memory module Disassembly, Remove the inner metal shield: 4 단계, 이미지 3개 중 2개 Cisco 878 Integrated Services Router StrataFlash Memory module Disassembly, Remove the inner metal shield: 4 단계, 이미지 3개 중 3개
      • 1. Gently lift up inner metal shield from the bottom of the router.
      • 2. Remove inner metal shield from the device (see the anchors on the picture).
      • Be careful and do not distort the plates!
      댓글 쓰기
    1. Cisco 878 Integrated Services Router StrataFlash Memory module Disassembly, Remove  StrataFlash Memory module: 5 단계, 이미지 3개 중 1개 Cisco 878 Integrated Services Router StrataFlash Memory module Disassembly, Remove  StrataFlash Memory module: 5 단계, 이미지 3개 중 2개 Cisco 878 Integrated Services Router StrataFlash Memory module Disassembly, Remove  StrataFlash Memory module: 5 단계, 이미지 3개 중 3개
      • 1. Place your fingers on the levers at the two sides of the slot, and push open.
      • 2. Firmly pull the release lever away from the module until the module pops up.
      • 3. You can then remove the module from the module slot.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
1다른 기여자 명과 함께
Jiri Altman
회원 가입일: 05/03/16
1,569 평판
안내서 9개를 작성함
4k20 Repair Team 4k20 Repair Team 회원
Community
2 회원들
안내서 92개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 36
전체 시간: 738
