주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ClickN Kids Tablet Touch Screen Display Replacement
필요한 것
    1. ClickN Kids Tablet Touch Screen Display Replacement, Touch Screen Display: 1 단계, 이미지 1개 중 1개
      • Start on the side with the camera. The screen side is black, the back side is colored
      • Insert a plastic opening tool into the space between the screen and the back side.
      댓글 쓰기
    2. ClickN Kids Tablet Touch Screen Display Replacement: 2 단계, 이미지 1개 중 1개
      • Press the plastic opening tool in until you hear a “click” and that part of the tablet opens.
      • Press and slide the plastic opening tool around all sides of the tablet until all sides pop off.
      댓글 쓰기
    3. ClickN Kids Tablet Touch Screen Display Replacement: 3 단계, 이미지 1개 중 1개
      • Lift the detached screen from the camera side until you can see the inside of the tablet.
      • Potential for device damage. Don't open too fast, or you might damage the ribbon cables.
      댓글 쓰기
    4. ClickN Kids Tablet Touch Screen Display Replacement: 4 단계, 이미지 2개 중 1개 ClickN Kids Tablet Touch Screen Display Replacement: 4 단계, 이미지 2개 중 2개
      • Potential for device damage. Be careful not to damage any wires or ribbon cables during this step.
      • There are two ribbon cables to remove during this step. Each is connected to a base on the motherboard.
      • There is a black tab behind the long ribbon cable. Lift up the black tab.
      • For the ribbon cable in the back, pull the black tabs on the side out.
      • Detach the ribbon cables connecting the screen to the motherboard.
      • Remove any tape that is holding down the ribbon cables. Set it aside.
      • Once the ribbon cables are freed, separate the top and bottom sides.
      댓글 쓰기
    5. ClickN Kids Tablet Touch Screen Display Replacement: 5 단계, 이미지 2개 중 1개 ClickN Kids Tablet Touch Screen Display Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the yellow tape on the right side. Easiest side to get.
      • Remove the black and yellow tape stuck together on the left and bottom sides of the screen.
      댓글 쓰기
    6. ClickN Kids Tablet Touch Screen Display Replacement: 6 단계, 이미지 1개 중 1개
      • Potential for device damage. Make sure the screen is facedown and level to prevent or reduce damage to the display.
      • Potential for device damage. There is an adhesive on the top edge of the display’s face. Be careful not to damage the display.
      • Flex the sides of the tablet until the clips holding the display to the screen case pop loose.
      댓글 쓰기
    7. ClickN Kids Tablet Touch Screen Display Replacement: 7 단계, 이미지 2개 중 1개 ClickN Kids Tablet Touch Screen Display Replacement: 7 단계, 이미지 2개 중 2개
      • Be careful not to damage the display or screen case.
      • Pull the display from the top side to detach it from the screen case.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Kevin Finney
회원 가입일: 03/22/15
562 평판
안내서 4개를 작성함
Baylor, Team 4-4, Williams Spring 2015 Baylor, Team 4-4, Williams Spring 2015 회원
BU-WILLIAMS-S15S4G4
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 47
전체 시간: 8,417
