주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Commodore 64 Removing the Shift-Lock Key
필요한 것
    1. Commodore 64 Removing the Shift-Lock Key, Removing the screws: 1 단계, 이미지 3개 중 1개 Commodore 64 Removing the Shift-Lock Key, Removing the screws: 1 단계, 이미지 3개 중 2개 Commodore 64 Removing the Shift-Lock Key, Removing the screws: 1 단계, 이미지 3개 중 3개
      • 1. Remove three 6.75mm ph2 screw heads from the casing.
      댓글 쓰기
    2. Commodore 64 Removing the Shift-Lock Key, Opening the Case: 2 단계, 이미지 1개 중 1개
      • 2. Split the case of the C64 open by pulling up on the case towards you
      • Do not pull too hard that you break the clips.
      댓글 쓰기
    3. Commodore 64 Removing the Shift-Lock Key, Removing screws (continued): 3 단계, 이미지 1개 중 1개
      • 3. Remove eight 6.75 mm ph2 screw heads to detach the keyboard face from the front casing. (Two remaining screws on the right side.)
      댓글 쓰기
    4. Commodore 64 Removing the Shift-Lock Key, Removing Screws (continued): 4 단계, 이미지 1개 중 1개
      • 4. Remove twenty-three 3.38 mm ph2 screw heads from the back of the keyboard facing
      댓글 쓰기
    5. Commodore 64 Removing the Shift-Lock Key, Removing the keyboard bundle cords from the motherboard: 5 단계, 이미지 3개 중 1개 Commodore 64 Removing the Shift-Lock Key, Removing the keyboard bundle cords from the motherboard: 5 단계, 이미지 3개 중 2개 Commodore 64 Removing the Shift-Lock Key, Removing the keyboard bundle cords from the motherboard: 5 단계, 이미지 3개 중 3개
      • 5. Detach the multi-colored wire bundles connected to the motherboard
      댓글 쓰기
    6. Commodore 64 Removing the Shift-Lock Key, Cutting the Wires: 6 단계, 이미지 1개 중 1개
      • 6. Next, carefully cut the two small wires which are connected from the Shift/Lock key to the keyboard.
      댓글 쓰기
    7. Commodore 64 Removing the Shift-Lock Key, Removing the Shift-Lock key: 7 단계, 이미지 2개 중 1개 Commodore 64 Removing the Shift-Lock Key, Removing the Shift-Lock key: 7 단계, 이미지 2개 중 2개
      • 7. Turn the keyboard down on its face and push the shift lock key out from the back of the keyboard.
      댓글 쓰기
    8. Commodore 64 Removing the Shift-Lock Key, Removal of circuit component from shift-lock key (optional): 8 단계, 이미지 1개 중 1개
      • 8. You can remove the circuit component (gray piece attached to the shift lock key spring) by pulling back slightly on its clip and pulling it apart from the shift lock key button.
      • * Take off the shift key button from the spring by using any Philips screwdriver to pry it off from the spring.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Silvanus Clarke
회원 가입일: 09/26/14
677 평판
안내서 5개를 작성함
USF Tampa, Team 13-6, Staggers Fall 2014 USF Tampa, Team 13-6, Staggers Fall 2014 회원
USFT-STAGGERS-F14S13G6
4 회원들
안내서 30개를 작성함
1가이드 댓글
You should desoder the shift lock wires. Not cut them :(
Darek Greenly - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 35
전체 시간: 3,012
