주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Compaq Evo N1000v Floppy Drive Replacement
필요한 것
    1. Compaq Evo N1000v Floppy Drive Replacement, LED Cover: 1 단계, 이미지 1개 중 1개
      • Flip the laptop over with the rear panel facing forward.
      댓글 쓰기
    2. Compaq Evo N1000v Floppy Drive Replacement: 2 단계, 이미지 1개 중 1개
      • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
      댓글 쓰기
    3. Compaq Evo N1000v Floppy Drive Replacement: 3 단계, 이미지 1개 중 1개
      • Flip the laptop back over with the front facing forward. Open the screen.
      댓글 쓰기
    4. Compaq Evo N1000v Floppy Drive Replacement: 4 단계, 이미지 1개 중 1개
      • Locate the F1 and F2 keys near the top left corner of the keyboard.
      댓글 쓰기
    5. Compaq Evo N1000v Floppy Drive Replacement: 5 단계, 이미지 1개 중 1개
      • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
      댓글 쓰기
    6. Compaq Evo N1000v Floppy Drive Replacement: 6 단계, 이미지 1개 중 1개
      • Locate the Scroll and Pause keys near the top right corner of the keyboard.
      댓글 쓰기
    7. Compaq Evo N1000v Floppy Drive Replacement: 7 단계, 이미지 1개 중 1개
      • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
      댓글 쓰기
    8. Compaq Evo N1000v Floppy Drive Replacement: 8 단계, 이미지 2개 중 1개 Compaq Evo N1000v Floppy Drive Replacement: 8 단계, 이미지 2개 중 2개
      • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
      댓글 쓰기
    1. Compaq Evo N1000v Floppy Drive Replacement, Keyboard: 9 단계, 이미지 1개 중 1개
      • Lift the back edge of the keyboard and pull towards the screen.
      댓글 쓰기
    2. Compaq Evo N1000v Floppy Drive Replacement: 10 단계, 이미지 1개 중 1개
      • Pull the cable and lift up to release.
      댓글 쓰기
    3. Compaq Evo N1000v Floppy Drive Replacement: 11 단계, 이미지 1개 중 1개
      • Remove the keyboard.
      댓글 쓰기
    1. Compaq Evo N1000v Floppy Drive Replacement, Palm Rest: 12 단계, 이미지 1개 중 1개
      • Close the laptop and flip it so the rear panel is facing up.
      댓글 쓰기
    2. Compaq Evo N1000v Floppy Drive Replacement: 13 단계, 이미지 1개 중 1개
      • Using the TR8 Torx screwdriver, remove the six screws from the back case.
      댓글 쓰기
    3. Compaq Evo N1000v Floppy Drive Replacement: 14 단계, 이미지 1개 중 1개
      • Remove the battery.
      • Remove the screw from the metal support on the case edge with a Torx T8 screwdriver.
      • Flip the laptop over again so the top is facing up.
      • Open the laptop screen and face it towards you.
      댓글 쓰기
    4. Compaq Evo N1000v Floppy Drive Replacement: 15 단계, 이미지 1개 중 1개
      • Lift the the palm rest up from the front edge of the laptop and swing it towards the screen.
      • Be gentle as it is connected by some cables.
      댓글 쓰기
    5. 댓글 쓰기
    6. Compaq Evo N1000v Floppy Drive Replacement: 17 단계, 이미지 1개 중 1개
      • Disconnect the second ribbon cable.
      댓글 쓰기
    7. Compaq Evo N1000v Floppy Drive Replacement: 18 단계, 이미지 1개 중 1개
      • Remove the palm rest.
      댓글 쓰기
      • Locate and remove the three screws shown in picture.
      댓글 쓰기
    1. Compaq Evo N1000v Floppy Drive Replacement: 20 단계, 이미지 1개 중 1개
      • Lift up and remove floppy drive from the palm rest.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Alex Hernandez
회원 가입일: 04/14/10
49 평판
안내서 4개를 작성함
Cal Poly, Team 29-74, Johann Spring 2010 Cal Poly, Team 29-74, Johann Spring 2010 회원
CPSU-JOHANN-S10S29G74
3 회원들
안내서 35개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 8
지난 30일: 30
전체 시간: 3,837
